Audi A8 4.2 40v AUW Engine Timing
Ok my old mans A8 was leant to friend and it overheated - water pump leaking like a sieve. So i bought the timing tools and a pump and set about begining the job. The problem being someone has done a timing belt with out the tools and now nothing lines up.
With the crank pin in and checked to be in the right position the cams do not line up. The engine ran fine before inspection so do i assume that the cams are in the correct position but the pulleys are offline? If a cambelt fails on these engines how do you align the camshaft timing i have one banks rocker cover off at the moment to see if there were any markings inside.
I want to put this back together properly by confirming the required position of the cams and reassembling everything in the correct manner.
I can't find any information on cam timing other then fitting the cam locking special tool which is no use here??
Any help greatly appreciated :)
James
Re: Audi A8 4.2 40v AUW Engine Timing
hey gupsterd thanks for the pm unfortunately i cannot return the favour until i reach 10 posts :) Cheers
And don't spam the forum just to raise your post count - they will be deleted.
I've only greated a few people in the newbie section and everything else has been genuine posts, thanks
James
That email is external... you don't need post count to email me on that...
cheers fella what i spanner i didn't even realise you had left details. Cheers for all your help
Gup you are a legend and credit to this forum fella thanks for sorting me the information that i needed.
muchos gracias
