I tighten the bolt that holds the anti roll bar links to the lower suspension arm. Are these bolts M12???? Can i drive it with one of them disconnected without causing damage?
Printable View
You COULD drive it but then I think the handling might be a bit off, not safe? not sure what size the bolt is did you get the old one out?
i havent got the old bolt off yet, it was getting late and my power drill had no battery. theres not much of a stud left, but i think theres enough to drill a bit and use some kind of stud extractor.
