A3 Central locking & elec windows not working
I have an A3 1.6 and the central locking / electric windows & electric sunroof have stopped working.
I have checked all fuses and replaced the electric window switch (drivers side)
I have also tried disconecting the battery then reconecting still no joy.
Please help as drivers window is part open.
Cheers Phil.:1zhelp:
Re: A3 Central locking & elec windows not working
if you've had the battery disconnected then you might have to reset them have a look in the manual it should tell you in there
Cheers for that, but have just had auto electrician look at it and he found a corroded wire at one of the terminal blocks that plug into the central locking pump, wire replaced and all good. Hope this helps someone in the future.
Phil.
