2.0 16V ABF - not starting after clearing fault codes.
Hi All
I have a strange problem, my mk3 anni has been running like a dream ever since i got her until today!
Basically I used a vgate VS450 to check & clear the fault codes for my abs light & now the car wont start!
The immobilizer turns off as normal but the car wont fire up, no ticking noises & the odd thing is the oil light flashes when i try to turn the engine.
I have tried re-setting the ecu by disconnecting the battery but it made no difference!
HELP!!
Re: 2.0 16V ABF - not starting after clearing fault codes.
Quote:
Originally Posted by
Roxy
Hi All
HELP!!
Roxy I know this is an old post but, what were the fault codes that you were clearing?Did you note down/the reader give you a printout or were you done carrying out a repair then clearing codes when this happened?
