Cruise Control cutting out
1999 Audi A4 Quattro - When cruising, any speeds, any length of time, the cruise control is just cutting out. I'll have it set for 2, 3, or even 45 minutes and all of a sudden it will just cancel itself and coast to a stop. When it cancels itself, it's hit or miss whether or not it will allow me to reset it. It never picks back up on it's own. I will try to set it as soon as it drops out and it sometimes it picks right back up. Other times, I will have to turn it off completely and wait a few minutes and turn it back on, and set it and it may/may not work. There doesn't seem to be any consistency and I'm in the northeast rural United States and we lack quality German mechanics to trouble shoot ANYTHING, so I'm very hesitant to take it anywhere. I was hoping one of the many qualified, experienced Audi owners could please :1zhelp:
Any suggestions as to what the culprit could be?
Re: Cruise Control cutting out
It could be the brake light switch, my cruise stopped working and this was the problem. I cleaned the Brake light switch and all was good.
It did happen again after that, so i bought a new one for £7, fitted that and its not happened since.
Next time it happenes, check if you have brake lights because you tend to loose both cruise and brake lights if its this switch.
http://www.geocities.com/jason_ettorre/VWBLS/BLS.htm
Don't forget there is a clutch switch as well.....if it is a manual.
It is in fact a manual, but I'm not sure what you mean by brake and clutch switches? Are you referring to fuses? Even then, I'm not sure where to check/clean that? I apologize for my ignorance, but I've never dealt with anything like this before.
If it answers your question, the brake lights still work since it has happened...? :confused:
When he cruise doesnt engage, that when you need to check your brake lights.
if you get in the footwell, look at the top of your brake pedal there is a switch as in the web link above.
Quote:
Originally Posted by
Lex Luthor
I agree with lex,check the clutch pedal switch operation in measured value blocks to confirm: look at block 66 to confirm beerchug:;
; VAG-COM Labelfile
; Audi A4 (8D) / Audi A6 (4B)
; Component: Engine (#01) - AGB/AJK/APB/ARE/AZA/AZB/BEL/BES
; P/N: 4B0-907-551-???
; 8D0-907-551-???
; 4B-01.LBL
; 4Z-01.LBL
; 8D-01.LBL
; 078-907-551-AZA.LBL (2.7l T @ 230-265 HP - AGB/AJK/APB/ARE/AZA/AZB/BEL/BES)
; requires VAG-COM 405.0 or newer
; coding information
C00,Engine Control Module (J220) Coding
C01,??xxx: Emissions
C02,05 = Euro II/D3 / 06 = TLEV (USA) / 07 = LEV (USA)
C03,08 = GUS/China / 10 = Euro III / 11 = Euro IV/Japan
C04,25 = South Africa / 26 = Mexico/Taiwan / 27 = Brasil
C05,
C06,xx?xx: Powertrain
C07,5 = Front-Wheel-Drive
C08,6 = All-Wheel-Drive without ASR/ESP (with CAN-Bus)
C09,7 = All-Wheel-Drive with ASR/ESP (with CAN-Bus)
C10,8 = All-Wheel-Drive with Post-Switch Stage (Low Range - A6 Allroad only)
C11,
C12,xxx?x: Transmission
C13,1 = 6-Speed Manual Transmission
C14,5 = 5-Speed Automatic Transmission (01V)
C15,
C16,xxxx?: Vehicle
C17,2 = Audi A6
C18,5 = Audi A6 Allroad
; measuring block information
000,0,General
000,1,Coolant Temperature (G69),Specification: 177...203 (85.0...105.0 °C)
000,2,Engine Load,Specification: 21...34 (15.0...26.0 %)
000,3,Engine Speed (G28),Specification: 67...73 (650...750 RPM)
000,4,Throttle Valve Angle,1...7 (0.40...2.75 %)
000,5,Idle Torque,Specification: 126...135 (-1.5...+1.5 %)
000,6,Torque Loss at Idle,Specification: 124...140 (-3.0...+5.0 %)
000,7,Mixture Adaptation Bank 1 Control Value (Idle),Specification: 122...136 (-4.0...+4.0 %)
000,8,Mixture Adaptation Bank 2 Control Value (Partial),Specification: 122...136 (-4.0...+4.0 %)
000,9,Mixture Adaptation Bank 1 Learned Value (Idle),Specification: 108...148 (-4.0...+4.0 %)
000,10,Mixture Adaptation Bank 2 Learned Value (Partial),Specification: 108...148 (-4.0...+4.0 %)
001,0,General
001,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
001,2,Coolant,Temperature (G69),Specification: 80.0...110.0 °C
001,3,Lambda Control,Bank 1,Range: -25.0...+25.0 %\nSpecification: -10.0...+10.0 %
001,4,Lambda Control,Bank 2,Range: -25.0...+25.0 %\nSpecification: -10.0...+10.0 %
002,0,General
002,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
002,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
002,3,Injection Timing,,Specification (Idle): 2.0...4.0 ms
002,4,Mass Air Flow,(G70),Specification (Load): min. 180.0 g/s
003,0,General
003,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
003,2,Mass Air Flow,(G70),Specification (Load): min. 180.0 g/s
003,3,Throttle Valve Angle
003,4,Ignition,Timing Angle
004,0,General
004,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
004,2,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
004,3,Coolant,Temperature (G69),Specification: 80.0...110.0 °C
004,4,Intake Air,Temperature (G42)
005,0,General
005,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
005,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
005,3,Vehicle Speed
005,4,Load Status,,Display Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
006,0,General
006,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
006,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
006,3,Intake Air,Temperature (G42)
006,4,Altitude,Correction Factor
010,0,Ignition
010,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
010,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
010,3,Throttle Valve Angle
010,4,Ignition,Timing Angle
011,0,Ignition
011,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
011,2,Coolant,Temperature (G69),Specification: 80.0...110.0 °C
011,3,Intake Air,Temperature (G42)
011,4,Ignition,Timing Angle
014,0,Ignition (Misfire Recognition - Total)
014,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
014,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
014,3,Misfire,(total),Specification: 0...15
014,4,Misfire,Recognition,Range: Disabled/Enabled
015,0,Ignition (Misfire Recognition - Cylinder 1-3)
015,1,Misfire Counter,Cylinder 1,Specification: 0...15
015,2,Misfire Counter,Cylinder 2,Specification: 0...15
015,3,Misfire Counter,Cylinder 3,Specification: 0...15
015,4,Misfire,Recognition,Range: Disabled/Enabled
016,0,Ignition (Misfire Recognition - Cylinder 4-6)
016,1,Misfire Counter,Cylinder 4,Specification: 0...15
016,2,Misfire Counter,Cylinder 5,Specification: 0...15
016,3,Misfire Counter,Cylinder 6,Specification: 0...15
016,4,Misfire,Recognition,Range: Disabled/Enabled
018,0,RPM/Load Barriers
018,1,Upper,RPM Barrier
018,2,Lower,RPM Barrier
018,3,Upper,Load Barrier
018,4,Lower,Load Barrier
020,0,Ignition (Timing Retardation Cylinder 1-4)
020,1,Timing Retardation,Cylinder 1,Specification: 0.0...12.0 CF
020,2,Timing Retardation,Cylinder 2,Specification: 0.0...12.0 CF
020,3,Timing Retardation,Cylinder 3,Specification: 0.0...12.0 CF
020,4,Timing Retardation,Cylinder 4,Specification: 0.0...12.0 CF
021,0,Ignition (Timing Retardation Cylinder 5-8)
021,1,Timing Retardation,Cylinder 5,Specification: 0.0...12.0 CF
021,2,Timing Retardation,Cylinder 6,Specification: 0.0...12.0 CF
022,0,Ignition (Timing Retardation Cylinder 1 && 2)
022,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
022,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
022,3,Timing Retardation,Cylinder 1,Specification: 0.0...12.0 CF
022,4,Timing Retardation,Cylinder 2,Specification: 0.0...12.0 CF
023,0,Ignition (Timing Retardation Cylinder 3 && 4)
023,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
023,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
023,3,Timing Retardation,Cylinder 3,Specification: 0.0...12.0 CF
023,4,Timing Retardation,Cylinder 4,Specification: 0.0...12.0 CF
024,0,Ignition (Timing Retardation Cylinder 5 && 6)
024,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
024,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
024,3,Timing Retardation,Cylinder 5,Specification: 0.0...12.0 CF
024,4,Timing Retardation,Cylinder 6,Specification: 0.0...12.0 CF
026,0,Ignition (Knock Control Cylinder 1-4)
026,1,Voltage,Cylinder 1
026,2,Voltage,Cylinder 2
026,3,Voltage,Cylinder 3
026,4,Voltage,Cylinder 4
027,0,Ignition (Knock Control Cylinder 5-6)
027,1,Voltage,Cylinder 5
027,2,Voltage,Cylinder 6
028,0,Ignition (Knock Sensor Test - Short Trip)
028,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
028,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
028,3,Coolant,Temperature (G69),Specification: 80.0...110.0 °C
028,4,Result,,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Syst. OK
030,0,Lambda Control (Sensor Status)
030,1,Bank 1,Sensor 1,Specification: 111\n\n1xx - Lambda Sensor Heating ON\nx1x - Lambda Sensor ready\nxx1 - Lambda Control active
030,2,Bank 1,Sensor 2,Specification: 110\n\n1xx - Lambda Sensor Heating ON\nx1x - Lambda Sensor ready\nxx1 - Lambda Control active
030,3,Bank 2,Sensor 1,Specification: 111\n\n1xx - Lambda Sensor Heating ON\nx1x - Lambda Sensor ready\nxx1 - Lambda Control active
030,4,Bank 2,Sensor 2,Specification: 110\n\n1xx - Lambda Sensor Heating ON\nx1x - Lambda Sensor ready\nxx1 - Lambda Control active
031,0,Lambda Control
031,1,Bank 1 Sensor 1,(actual),Range: 0.000...1.000 V
031,2,Bank 1 Sensor 1,(specified),Range: 0.000...1.000 V
031,3,Bank 2 Sensor 1,(actual),Range: 0.000...1.000 V
031,4,Bank 2 Sensor 1,(specified),Range: 0.000...1.000 V
032,0,Lambda Control (Mixture Adaptation)
032,1,Adaptation (Idle),Bank 1 Sensor 1,Range: -25.0...+25.0 %\nSpecification: -4.0...+4.0 %
032,2,Adaptation (Partial),Bank 1 Sensor 1,Range: -25.0...+25.0 %\nSpecification: -4.0...+4.0 %
032,3,Adaptation (Idle),Bank 2 Sensor 1,Range: -25.0...+25.0 %\nSpecification: -4.0...+4.0 %
032,4,Adaptation (Partial),Bank 2 Sensor 1,Range: -25.0...+25.0 %\nSpecification: -4.0...+4.0 %
033,0,Lambda Control
033,1,Lambda Control,Bank 1 Sensor 1,Range: -25.0...+25.0 %\nSpecification: -4.0...+4.0 %
033,2,Sensor Voltage,Bank 1 Sensor 1,Range: 0.000...1.000 V
033,3,Lambda Control,Bank 2 Sensor 1,Range: -25.0...+25.0 %\nSpecification: -4.0...+4.0 %
033,4,Sensor Voltage,Bank 2 Sensor 1,Range: 0.000...1.000 V
034,0,Lambda Control (Lambda Sensor Aging - Bank 1 Sensor 1)
034,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
034,2,Catalytic Converter,Bank 1 Temp.,Range: 70.0...850.0 °C\nSpecification: min. 260.0 °C
034,3,Dynamic Factor,Bank 1 Sensor 1,Range: 0.0...3.0 s\nSpecification: 0.1...1.0 s
034,4,Result,Lambda Aging,Range: Test ON/Test OFF/B1-S1 not OK/B1-S1 OK\nSpecification: B1-S1 OK
035,0,Lambda Control (Lambda Sensor Aging - Bank 2 Sensor 1)
035,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
035,2,Catalytic Converter,Bank 2 Temp.,Range: 70.0...850.0 °C\nSpecification: min. 260.0 °C
035,3,Dynamic Factor,Bank 2 Sensor 1,Range: 0.0...3.0 s\nSpecification: 0.1...1.0 s
035,4,Result,Lambda Aging,Range: Test ON/Test OFF/B2-S1 not OK/B2-S1 OK\nSpecification: B2-S1 OK
036,0,Lambda Control (Sensor Readiness - After Catalyst)
036,1,Sensor Voltage,Bank 1 Sensor 2,Range: 0.000...1.000 V
036,2,Result,Lambda Availability,Range: Test ON/Test OFF/B1-S2 not OK/B1-S2 OK\nSpecification: B1-S2 OK
036,3,Sensor Voltage,Bank 2 Sensor 2,Range: 0.000...1.000 V
036,4,Result,Lambda Availability,Range: Test ON/Test OFF/B2-S2 not OK/B2-S2 OK\nSpecification: B2-S2 OK
037,0,Lambda Control (Correction Bank 1)
037,1,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
037,2,Sensor Voltage,Bank 1 Sensor 2,Range: 0.000...1.000 V
037,3,Correction Value,Bank 2,Specification: -500.0...+500.0 ms\nRange: -1200.0...+1200.0 ms
037,4,Result,,Range: Test ON/Test OFF/Syst. OK/Syst. n.OK\nSpecification: Syst. OK
038,0,Lambda Control (Correction Bank 2)
038,1,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
038,2,Sensor Voltage,Bank 2 Sensor 2,Range: 0.000...1.000 V
038,3,Correction Value,Bank 2,Specification: -500.0...+500.0 ms\nRange: -1200.0...+1200.0 ms
038,4,Result,,Range: Test ON/Test OFF/Syst. OK/Syst. n.OK\nSpecification: Syst. OK
041,0,Lambda Control (Lambda Sensor Heating Bank 1)
041,1,Resistance,Bank 1 Sensor 1,Specification: 0.0...0.5 kOhm
041,2,Heater Condition,Bank 1 Sensor 1,Range: Htg. S1 OFF/Htg. S1 ON
041,3,Resistance,Bank 1 Sensor 2,Specification: 0.0...0.5 kOhm
041,4,Heater Condition,Bank 1 Sensor 2,Range: Htg. S2 OFF/Htg. S2 ON
042,0,Lambda Control (Lambda Sensor Heating Bank 2)
042,1,Resistance,Bank 2 Sensor 1,Specification: 0.0...0.5 kOhm
042,2,Heater Condition,Bank 2 Sensor 1,Range: Htg. S1 OFF/Htg. S1 ON
042,3,Resistance,Bank 2 Sensor 2,Specification: 0.0...0.5 kOhm
042,4,Heater Condition,Bank 2 Sensor 2,Range: Htg. S2 OFF/Htg. S2 ON
043,0,Lambda Control (Lambda Sensor Aging - Bank 1 Sensor 2)
043,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
043,2,Catalytic Converter,Bank 1 Temp.,Range: 70.0...850.0 °C\nSpecification: min. 320.0 °C
043,3,Sensor Voltage,Bank 1 Sensor 2,Range: 0.000...1.000 V
043,4,Result,Aging Check,Display Range: Test ON/Test OFF/B1-S2 OK/B1-S2 n.OK\nSpecification: B1-S2 OK
044,0,Lambda Control (Lambda Sensor Aging - Bank 2 Sensor 2)
044,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
044,2,Catalytic Converter,Bank 2 Temp.,Range: 70.0...850.0 °C\nSpecification: min. 320.0 °C
044,3,Sensor Voltage,Bank 2 Sensor 2,Range: 0.000...1.000 V
044,4,Result,Aging Check,Display Range: Test ON/Test OFF/B2-S2 OK/B2-S2 n.OK\nSpecification: B2-S2 OK
046,0,Lambda Control (Catalytic Conversion Test Bank 1)
046,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
046,2,Catalytic Converter,Bank 1 Temp.,Range: 70.0...850.0 °C\nSpecification: min. 350.0 °C
046,3,Catalytic,Conversion Bank 1,Range: 0.00...0.99\nSpecification: 0.00...0.80
046,4,Result,Cat. Conversion,Display Range: Test ON/Test OFF/CatB1 OK/CatB1 n.OK\nSpecification: CatB1 OK
047,0,Lambda Control (Catalytic Conversion Test Bank 2)
047,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
047,2,Catalytic Converter,Bank 2 Temp.,Range: 70.0...850.0 °C\nSpecification: min. 350.0 °C
047,3,Catalytic,Conversion Bank 2,Range: 0.00...0.99\nSpecification: 0.00...0.80
047,4,Result,Cat. Conversion,Display Range: Test ON/Test OFF/CatB2 OK/CatB2 n.OK\nSpecification: CatB2 OK
050,0,Engine Speed Increase
050,1,Engine Speed,(actual),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
050,2,Engine Speed,(specified)
050,3,A/C Readiness,,Range: A/C-Low / A/C-High
050,4,A/C Compressor,,Range: Compr.OFF/Compr.ON
051,0,Engine Speed Increase (Gear Shifts)
051,1,Engine Speed,(actual),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
051,2,Engine Speed,(specified)
051,3,Selected Gear,,Range: P or N = 0/Gear = 1 - 6/R = 7
051,4,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
053,0,Engine Speed Increase (Generator Load)
053,1,Engine Speed,(actual),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
053,2,Engine Speed,(specified)
053,3,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
053,4,Generator Load,,Range: 0.0...100.0 %
054,0,Idle Speed Stabilization
054,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
054,2,Load Status,,Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
054,3,Accel. Pedal Pos.,Sensor 1 (G79),Specification: 12.0...97.0 %
054,4,Throttle Valve Angle
055,0,Idle Speed Stabilization
055,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
055,2,Idle Regulator
055,3,Idle Stabilization,Self-Adaptation
055,4,Operating,Condition
; --?xx = A/C Readiness (0 = Minimum Output / 1 = Maximum Output)
; --x?x = Gear Status (0 = P/N / 1 = 2/3/4/R/D)
; --xx? = A/C Compressor (0 = OFF / 1 = ON)
056,0,Idle Speed Stabilization
056,1,Engine Speed,(actual),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
056,2,Engine Speed,(specified)
056,3,Idle Regulator
056,4,Operating,Condition
060,0,Electronic Throttle Adaptation
060,1,Throttle Valve,Sensor 1 (G187),Specification: 3.0...93.0 %
060,2,Throttle Valve,Sensor 2 (G188),Specification: 97.0...3.0 %
060,3,Throttle Adaptation,Steps Counter,Specification: 0\nRange: 0...8
060,4,Result,Throttle Valve Adp.,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
061,0,Electronic Throttle
061,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
061,2,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
061,3,Throttle Valve Angle
061,4,Operating,Condition
062,0,Electronic Throttle
062,1,Throttle Valve,Sensor 1 (G187),Specification: 3.0...93.0 %
062,2,Throttle Valve,Sensor 2 (G188),Specification: 97.0...3.0 %
062,3,Accel. Pedal Pos.,Sensor 1 (G79),Specification: 12.0...97.0 %
062,4,Accel. Pedal Pos.,Sensor 2 (G185),Specification: 4.0...49.0 %
063,0,Electronic Throttle (Kick-Down Adaptation)
063,1,Accel. Pedal Pos.,Sensor 1 (G79),Specification: 12.0...97.0 %
063,2,Accel. Pedal Pos.,Sensor 2 (G185),Specification: 4.0...49.0 %
063,3,Kick-Down,Switch,Range: Kick Down/Not Oper.
063,4,Kick-Down,Adaptation,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
064,0,Throttle Valve Sensor Adaption Values
064,1,Lower Adaptation,Sensor 1 (G187)
064,2,Lower Adaptation,Sensor 2 (G188)
064,3,Emergency Air Gap,Sensor 1 (G187)
064,4,Emergency Air Gap,Sensor 2 (G188)
066,0,Cruise Control System
066,1,Vehicle Speed,(current)
066,2,Switch Positions I
; 1xxx = Cruise Control System active
; x1xx = Clutch operated (always 1 with Automatic Transmission)
; xx1x = Brake operated (Brake Pedal Switch)
; xxx1 = Brake operated (Brake Light Switch)
066,3,Vehicle Speed,(specified)
066,4,Switch Positions II
070,0,Emission Reduction (TEV - Basic Setting)
070,1,Evap. Emissions,Sol. Valve,Range: 0.0...100.0 %
070,2,Lambda Control,(During Diagnosis),Range: -25.0...+25.0 %\nSpecification: -5.0...+4.0 %
070,4,Result,,Range: Test ON/Test OFF/TEV OK/TEV not OK
071,0,Emission Reduction (Basic Setting: Leak Diagnostic System)
071,1,Reed Contact,Condition,Range: Reed Open/Reed Closed
071,4,Result,Leak Test,Range: Test ON/Test OFF/Syst. OK/Syst. not OK
077,0,Emission Reduction (Secondary Air Injection System Bank 1)
077,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
077,2,Mass Air Flow,(G70),Specification (Load): min. 180.0 g/s
077,3,Secondary Air,System Air Mass,Range: -100.0...+10.0 %
077,4,Result,,Range: Test ON/Test OFF/Syst. OK/Syst. not OK
078,0,Emission Reduction (Secondary Air Injection System Bank 2)
078,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
078,2,Mass Air Flow,(G70),Specification (Load): min. 180.0 g/s
078,3,Secondary Air,System Air Mass,Range: -100.0...+10.0 %
078,4,Result,,Range: Test ON/Test OFF/Syst. OK/Syst. not OK
081,0,Advanced Control Module Identification II
082,0,Advanced Control Module Identification III
089,0,On-Board-Diagnostics (OBD)
089,1,Distance Driven,with MIL on
089,2,Tank Condition,,Display Range: OK/too low
090,0,Continuous Camshaft Adjustment (Intake)
090,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
090,2,Adjustment,Status,Range: Cam Ctrl. ON/Cam Ctrl. OFF
090,3,Adjustment,Bank 1
090,4,Adjustment,Bank 2
091,0,Continuous Camshaft Adjustment (Intake - Bank 1)
091,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
091,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %´
091,3,Adjustment,Status,Range: Cam Ctrl. ON/Cam Ctrl. OFF
091,4,Adjustment,Bank 1
092,0,Continuous Camshaft Adjustment (Intake - Bank 2)
092,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
092,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
092,3,Adjustment,Status,Range: Cam Ctrl. ON/Cam Ctrl. OFF
092,4,Adjustment,Bank 2
093,0,Continuous Camshaft Adjustment (Phase Position - Bank 1 && 2)
093,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
093,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
093,3,Phase Position,Bank 1,Range: -20.3...+14.8 CF\nSpecification (Idle): 0 CF (± 6 CF)
093,4,Phase Position,Bank 2,Range: -20.3...+14.8 CF\nSpecification (Idle): 0 CF (± 6 CF)
094,0,Continuous Camshaft Adjustment (Intake)
094,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
094,2,Adjustment,Status,Range: Cam Ctrl. ON/Cam Ctrl. OFF
094,3,Result,Bank 1,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Syst. not OK
094,4,Result,Bank 2,Range: Test ON/Test OFF/Syst. OK/Syst. not OK\nSpecification: Syst. not OK
099,0,Lambda Control Shut-Off (Basic Setting)
099,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
099,2,Coolant,Temperature (G69),Specification: 80.0...110.0 °C
099,3,Lambda Control
099,4,Lambda Control,Status,Display Range: O2-Reg.OFF/O2-Reg.ON
100,0,Readiness Code
100,1,Readiness Bits
; 1xxxxxxx - Exhaust Gas Recirculation (EGR)
; x1xxxxxx - Sensor Heater
; xx1xxxxx - Oxygen Sensors
; xxx1xxxx - A/C System
; xxxx1xxx - Secondary Air Injection (AIR) System
; xxxxx1xx - Activated Charcoal System
; xxxxxx1x - Catalytic Converter Heater
; xxxxxxx1 - Catalytic Converter
100,2,Coolant,Temperature (G69),Specification: 80.0...110.0 °C
100,3,Time since,Engine Start
100,4,OBD-Status
; 1xxx--xx - MIL Warning Lamp ON
; x1xx--xx - Driving Cycle detected
; xx1x--xx - Trip complete
; xxx1--xx - Malfunction detected (1+)
; xxxx--1x - Heating cycle ended
; xxxx--x1 - Heating cycle not possible
101,0,Fuel Injection
101,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
101,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
101,3,Injection Timing,,Specification (Idle): 2.0...4.0 ms
101,4,Mass Air Flow,(G70),Specification (Load): min. 180.0 g/s
102,0,Fuel Injection
102,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
102,2,Coolant,Temperature (G69),Specification: 80.0...110.0 °C
102,3,Intake Air,Temperature (G42)
102,4,Injection Timing,,Specification (Idle): 2.0...4.0 ms
104,0,Start Adaption Values
104,1,Start Engine,Temperature
104,2,Temperature,Adaptation Factor 1
104,3,Temperature,Adaptation Factor 2
104,4,Temperature,Adaptation Factor 3
107,0,Lambda Control
107,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
107,2,Lambda Control,Bank 1 (Average),Range: -25.0...+25.0 %\nSpecification: -18.0...+12.0 %
107,3,Lambda Control,Bank 2 (Average),Range: -25.0...+25.0 %\nSpecification: -18.0...+12.0 %
107,4,Result,Lambda Control,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK\nSpecification: Syst. OK
110,0,Load/Full Throttle Enrichment
110,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
110,2,Coolant,Temperature (G69),Specification: 80.0...110.0 °C
110,3,Injection Timing,,Specification (Idle): 2.0...4.0 ms
110,4,Throttle Valve Angle
111,0,Boost Pressure Control
111,1,RPM Range 1
111,2,RPM Range 2
111,3,RPM Range 3
111,4,RPM Range 4
112,0,Exhaust Gas Temperature
112,1,Exhaust Gas,Temperature Bank 1
112,2,Enrichment Factor,Bank 1
112,3,Exhaust Gas,Temperature Bank 2
112,4,Enrichment Factor,Bank 2
113,0,Load/Full Throttle Enrichment
113,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
113,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
113,3,Throttle Valve Angle
113,4,Athmospheric,Pressure
114,0,Boost Pressure Control
114,1,Engine Load,(specified),Tolerance (to Field 2 & 3): max. ±5.0 %
114,2,Engine Load,(spec. corrected),Tolerance (to Field 1 & 3): max. ±5.0 %
114,3,Engine Load,(actual),Tolerance (to Field 1 & 2): max. ±5.0 %
114,4,Wastegate (N75),Duty Cycle
115,0,Boost Pressure Control
115,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
115,2,Engine Load,,Specification (Idle): 15.0...25.0 %\nRange: 15.0...175.0 %
115,3,Boost Pressure,(specified)
115,4,Boost Pressure,(actual),Tolerance (to Spec.): max. ±20 mbar
116,0,Boost Pressure Control
116,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
116,2,Fuel Temp.,Correction Factor,Specification: min. 0.0 %
116,3,Coolant Temp.,Correction Factor,Specification: min. 0.0 %
116,4,Intake Air Temp.,Correction Factor,Specification: min. 0.0 %
117,0,Boost Pressure Control
117,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
117,2,Accel. Pedal Pos.,Sensor 1 (G79),Specification: 12.0...97.0 %
117,3,Throttle Valve Angle
117,4,Boost Pressure,(specified)
118,0,Boost Pressure Control
118,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
118,2,Intake Air,Temperature (G42)
118,3,Wastegate (N75),Duty Cycle
118,4,Boost Pressure,(actual)
119,0,Boost Pressure Control
119,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
119,2,Charge Limit
119,3,Wastegate (N75),Duty Cycle
119,4,Boost Pressure,(actual)
120,0,Traction Control (ASR)
120,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
120,2,Torque specified,by ASR
120,3,Engine Torque,(actual)
120,4,Status,,Specification: ASR OFF/ASR ON
122,0,Transmission
122,1,Engine Speed,(G28),Specification (Idle): 650...750 RPM\nSpecification (Load): 1900...2200 RPM\nRange: 0...6800 RPM
122,2,Torque specified,by Transmission
122,3,Engine Torque,(actual)
122,4,Status,,Display Range: No Torq Red/Torq. Reduc.
125,0,CAN-Databus Communication (Powertrain)
125,1,Transmission
125,2,Brake Electronics,(J104),Range: ABS 1/ABS 0\nSpecification: ABS 1
125,3,Instrument Cluster,(J285),Range: Instruments 1/Instruments 0\nSpecification: Instruments 1
