Any advice welcome on my Airbag Light Problem
First of all i,d like to say hello, My name is David.
The Airbag Light on my 2001 A2 TDI 75 has been on a while now and i finally got round to doing a diagnostic scan on it.
The result of the scan can up with this fault code:- 00588 - Airbag Igniter; Driver Side (N95): Resistance too High
00588 - Airbag Igniter; Driver Side (N95): Resistance too Low
00588 - Airbag Igniter; Driver side (N95): Short to positive
00588 - Airbag Igniter; Driver side (N95): Short to ground
Possible Symptoms
- Airbag Warning Light active
Possible Causes
- Wiring from/to Airbag Igniter Driver Side (N95) faulty
- Coil Spring with Slip Ring (F138) faulty
- Airbag Igniter Driver Side (N95) faulty
Possible Solutions
- Check Wiring from/to Airbag Igniter Driver Side (N95)
- Check Coil Spring with Slip Ring (F138)
- Check Airbag Igniter Driver Side (N95)
Special Notes
- When "Short to positive" or "Short to ground" is found, DO NOT CLEAR THE DTC. This can cause the airbag to deploy. See repair manual for more information.
Category: Fault Codes
Categories
Meta
http://wiki.ross-tech.com/wiki/images/vegas.jpg
I would just like to ask if anyone else has had this problem and if so how was it remeded.
Any advice is trully welcome. Also if im not allowed to put the infomation above the way i have im sorry and wont do it again.
Cheers David
Re: Any advice welcome on my Airbag Light Problem
the wiring plug under the seats, same as the golf, VW recommend to cut the plug out and solder the wires instead of using the multi plugs, mine needs doing as the bong and airbag light is doing my head in
Thank you fella, I,ll book it in for this sorting out.
Quote:
Originally Posted by
drakeman70
Anytime mate
