B6 2.0TDi sluggish pullaway
My passat b6 2.0 TDi is not easy to control at busy junctions. It's very difficult to get a quick controlled pull away. It seems to either bog down or tear away with wheels spinning - is it me or the car? Is there a technique I need to master here? (apart from smoking the clutch ;-) )
Roy
Re: B6 2.0TDi sluggish pullaway
I'm experiencing exactly the same symptoms with my '55' reg B6 2.0TDI SE; sluggish off the mark (unless you slip the clutch - and then it wheelspins like fury), accompanied by what I think, in comparison the PD130 that it replaced, excessive smoking. On occaision it also seems to get 'bogged down' if you're moving slowing in 2nd and then try to accelerate; when it does pick up heaven help anyone behind - the smoke is horrendous!
The dealer say's that they've done all of the software upgrades, and that there's nothing wrong with it. In all not as pleased with it as I remember being with my 130PD - will chop in in next year if I can't get a fix.
