Full scan results
Can anyone help me with the following full scan results, by which I mean what is wrong???
Version:0.9 StartHtml: 105 EndHtml: 10204 StartFragment: 334 EndFragment: 10172
Address 01: Engine Controller: 038 906 019 GL Component: 1,9l R4 EDC 0000SG 1495 Coding: 00002 Shop #: WSC 00028 WVWZZZ3BZ3P388278 VWZ7Z0C7080365 No fault code found. Readiness: N/A
-------------------------------------------------------------------------------Address 03: ABS Brakes Controller: 4B0 614 517 G Component: ABS/ESP front 3428 Coding: 04255 Shop #: WSC 00028 2 Faults Found: 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent
-------------------------------------------------------------------------------Address 08: Auto HVAC Controller: 3B1 907 044 J Component: CLIMATRONIC B5GP 0006 Coding: 17000 Shop #: WSC 00028 1 Fault Found: 01274 - Air Flow Flap Positioning Motor (V71) 37-00 - Faulty
-------------------------------------------------------------------------------Skipping Address 15-Airbags
[IMG]file:///C:/Users/Peter/AppData/LocalLow/Temp/Microsoft/OPC/DDT.aratgf1q8uy541754mab438z.tmp[/IMG]
VAG-COM Self-Diagnosis Log Sunday, 01 January 2012, 14:51:53 Page 2
VIN Number: WVWZZZ3BZ3P388278 License Plate: TOMS CAR
[IMG]file:///C:/Users/Peter/AppData/LocalLow/Temp/Microsoft/OPC/DDT.m3bpq42_xfiv2m7_w16bn5bpg.tmp[/IMG]
Address 17: Instruments Controller: 3B0 920 927 A Component: KOMBI+WEGFAHRSP VDO V08 Coding: 05415 Shop #: WSC 00696 WVWZZZ3BZ3P388278 VWZ7Z0C7080365 1 Fault Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent
-------------------------------------------------------------------------------Address 19: CAN Gateway Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 00028 1 Fault Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent
-------------------------------------------------------------------------------Address 46: Central Conv. Controller: 1C0 959 799 B Component: 6T Komfortgerát HLO 0003 Coding: 00258 Shop #: WSC 00028 No fault code found.
-------------------------------------------------------------------------------Address 56: Radio Controller: 1J0 035 186 D Component: RADIO SON 0004 Coding: 04403 Shop #: WSC 00028 No fault code found.
End --------------------------------------------------------------------------------------------------
