Will the 2000 face lift rear lights fit on 96 (saloon) ?
Are the plugs or wiring different ?
The orange rear indicators just don't go with a black car.
Printable View
yes they do,i have done this.all u have to do is swap the indicator and reverse lights over.ie cut the main feed to the bulb holder and swop around.its dead easy.ill have a look 2morrow and tell ya wot wires to cut and join;)
aaagh dont cut them the wires come out of the plugs pull out the retaining clip and there is a little metal clip in the plug which is part of the connecter lift it up with a needle or similar and swap them over you can trace the wires on the bulb holder buy seein which one you want to light up but >96 bulb holder are different they have a separate side light you need bulb holders 98 on but they are cheap even from dealers
cheers
unless its a really early a4 paul is correct,the ones that ahave the small reverse lights.my wifes car is 96 and has thesehttp://i201.photobucket.com/albums/a...ks/utah004.jpg
my 98 model had the same as the wifes,i changed these to the 99 model on. bulb holders where the same.wireing colours that need to be swopped round are, black/green and blue/redhttp://i201.photobucket.com/albums/a...ks/utah005.jpg
the early ones look something like these but im sure theres another version of these as well,same sort of layout.http://i201.photobucket.com/albums/a...a4rearlamp.jpg
