Re: Parking brake problems
Clear the errors, wait a few days and scan again, see if anything comes back. You may have a faulty switch or it may just be an odd error. These can occur when the system gets confused.
I had a simlar experience but in mine the park brake would not switch off. I was at a fuel station and it was embarresing! I disconnected the battery, waited 10 secs and reconnected. The park brake switch functioned OK.
I carried out a scan when I got home and the DTC for park brake failure was live. I subsequentely replaced the switch, cleared the DTC and had no more problems. I understand that the switches have been the source of a few problems as my dealer had some in stock. Good luck.
is there a lot involved in replacing the epb switch? how do you remove it and the trim around it, thanks.
Quote:
Originally Posted by
monzo24
Dead easy - ignition off, key out, open the drivers door, and on the side of the dashboard there is a removable plastic panel - pop it off (it only clips on) to open up the side of the dashboard, and you will see the wires going into the wiring plug at the back of the switch. Simply push the switch from behind so it pops out the front of the dash, which will then give you access to the plug; there is a small locking tab which needs to be popped up to allow the plug to be unplugged.
And to steal a phrase from good old Haynes manuals - fitting is the reverse of removal.
ok thanks for that. Now as the epb seems to be pretty unreliable, at least the switch and calipers can be, is it worth me investing in a epb service tool. This tool similar to the can bus scan and reset tool, opens and closes the calipers for when replacing pads. Would this get us out of trouble in the event of a epb switch failure , say if the brakes won't release or other problem. Or is it an expensive £60 peace of mind item.
If a caliper sticks you can take the motor off and wind it back half a turn to release it. You need the EPB tool only if you are going to change the rear pads. It is possible to change the pads without the tool but it involves a bit of luck.
Hello again
I have just done another and some of the same faults have come up again.
Any thoughts?
Thursday,10,November,2011,14:51:00:44707
VCDS Version: Release 10.6.5
Data version: 20110930
Chassis Type: 3C0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ9P045898 Mileage: 74870km/46522miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BL HW: 03L 907 309
Component: R4 2,0L EDC G000SG 3570
Revision: 13H01--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00235 941 176675
VCID: 70E42D371A38
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 3C0-614-109-C4.lbl
Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
Component: J104 C4 440 V2 0011
Revision: --025--- Serial number: 00000786265199
Coding: 0001298
Shop #: WSC 00028 028 00001
VCID: 2B5EFA5BF39E
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HN HW: 1K0 820 047 HN
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 77F6162B7F56
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 AB HW: 3C8 937 049 AB
Component: Bordnetz-SG H57 3204
Revision: 00H57000 Serial number: 00000004104542
Coding: E0808F0700041A00470A00000F000000008859C35C00012000 0000000000
Shop #: WSC 00235 941 98775
VCID: 71E228331132
Part No: 3C2 955 119 B
Component: Wischer 030908 022 0601
Coding: 00046997
Shop #: WSC 00235
Part No: 1K0 955 559 AF
Component: RLS 141008 046 0204
Coding: 00208933
Shop #: WSC 00235
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__006 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPL90LDS
Coding: 0012342
VCID: 3B7ECA1B03FE
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AE HW: 3C0 953 549 AE
Component: J0527 0020
Revision: 00026000 Serial number: 3C5953507AT
Coding: 0000111
VCID: 6FE62E4B0706
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 E HW: 3C0 920 971 E
Component: KOMBIINSTRUMENT VD1 2416
Revision: V0002000 Serial number: 00000000000000
Coding: 0007405
Shop #: WSC 00235 941 85967
VCID: 2756066BEF76
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 L HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 3300P08A1409CC
Coding: F9807F06000202001003
VCID: 2A50FF5FFC64
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 7AF00F1F4C44
Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1518
Revision: 71009005 Serial number: 00000315588705
Coding: 0004791
VCID: 71E228331132
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 195 2301
Revision: 00H15000
VCID: 2A50FF5FFC64
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 043 0612
Coding: 01910A0001860E763004941570085FCE107C01
VCID: 7AF00F1F4C44
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H08 9001
Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Component: Innenraumueberw.004 0611
1 Fault Found:
01038 - Central Locking Thermal Protection
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 4
Reset counter: 150
Mileage: 74510 km
Time Indication: 0
Date: 2011.11.05
Time: 08:59:27
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1518
Revision: 71009005 Serial number: 00000295288822
Coding: 0004790
VCID: 72E0273F1434
Address 53: Parking Brake Labels: 5N0-907-801.lbl
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000169997
Coding: 0000057
Shop #: WSC 00594 941 76527
VCID: 28540557E268
2 Faults Found:
03200 - Switch for Electric Parking Brake (E538)
Freeze Frame:
Fault Status: 00111100
Fault Priority: 1
Fault Frequency: 4
Reset counter: 167
Mileage: 74715 km
Time Indication: 0
Date: 2011.11.08
Time: 08:07:02
Freeze Frame:
Voltage: 13.40 V
Count: 10
Speed: 0.0 km/h
Hex Value: 0x1170
Hex Value: 0x0008
Hex Value: 0x0101
16352 - Control Module - Electrical Error
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 6
Reset counter: 171
Mileage: 74715 km
Time Indication: 0
Date: 2011.11.08
Time: 08:07:02
Freeze Frame:
Voltage: 13.50 V
Count: 42
Speed: 0.0 km/h
Hex Value: 0x1160
Hex Value: 0x0008
Hex Value: 0x0101
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 012 0029
Revision: 00000000 Serial number: VWZ1Z2H5809204
Coding: 0500040004
VCID: 65CA4C63D5FA
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 100
Mileage: 74310 km
Time Indication: 0
Date: 2011.10.28
Time: 22:39:41
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0308
Revision: 41004101 Serial number: 00000000651691
Coding: 0000144
VCID: 70E42D371A38
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0308
Revision: 41004101 Serial number: 00000000645422
Coding: 0000144
VCID: 71E228331132
I would replace the EPB switch and see what happens. It shouldn't be a fault with the actual brakes. The system runs a sort of " time-out", so it may flag that the switch is not activating quick enough.
