hi , can anyone tell me if a 18" alloy with 225x40x18 will fit in spare wheel well on 02 golf gt tdi :confused:
Printable View
Yeah, it will go in but your boot liner might not drop all the way back down as they are about 30mm wider than your standard wheels.:D
will it be an eye sore ??
It will only be an eyesore if you look in the boot a lot, It may even be ok have a look and see how much clearance is there like i said in the previous post the 225 tyre is about 30mm or 1 1/4"wider than the standard 195.:D
cheers steve , i think i'll give it a miss as i'm in and out of boot loads and i don't want to have something rolling around in boot if its not a flat surface , footwell on r32 must be slightly bigger eh
