Re: Replace a Clutch Switch
This has got me thinking................
all of my reversing sensors click when the car is in reverse so it would appear that they're all working.
My reverse lights work fine.
But sometimes when I engage reverse I get a long error sound, or nothing at all. So my sensors don't always work properly.
I'm wondering if my clutch switch could be faulty?
Would a faulty switch cause intermittent errors when selecting reverse?
I'm pretty sure you are NOT meant to touch the pedal whilst installing the switch - it's def like that with VW's brake switches :confused:
edit - don't twist the switch into place with the pedal depressed
http://forums.vwvortex.com/showthrea...ut-breaking-it
Hi all,
Just done this service yesterday - took the best part of 10 mins - its pretty simple bar the knee panel a bit tricky cause the screws are slightly angled. Twist counter clockwise clicks twice its out - put the new switch in exactly as the old one came out and pow all done.
£15 inc. Vat @ 20% genuine part 10 mins work better than the figures they quoted me at the dealers...
Thanks to all for posting great posts to aid in the service - good look!!!
Nicely done, Pdlh. After replacing what I thought was the clutch switch (twice), I found your post and realized I was replacing the starter control switch. Thanks to you, I have now done the job right and cruise control is working again.
Much appreciated.
OneGun.
How many miles are you all at with your cars? I recently fitted cruise @ 57k. Wondering when this is likely to happen.
Quote:
Originally Posted by
GarJE
mine just went at 141k.... £15-something incl VAT.
GarJE
I don't know that the issue is related to the number of miles precisely, I fitted cruise at 67k miles and the switch had already failed, for all I know it could have failed at 10k, as the car did not have cruise, the previous owner would not have known it was an issue. The one thing that seems a dead certain from various posts on this forum in the past year is the likelihood of a clutch switch failure on a late 56 reg, 07 and 57 is almost guaranteed. It's just a matter of time. It really seemed Audi bought a bad batch of switches from their supplier. More so, they have kind of admitted it was as issue by making the replacement switch you purchase from the dealer look like it has been seriously redesigned and improved.
Paul
Not being the worlds greatest car mechanic, what would the symptoms be if the clutch switch failed?, i have a 05 2ltdi with cruise control, its done 140k and apart from the air con pump pulley everything seems ok.
sar02
The cruise would not work and the engine tends to over rev on gear changes.
I wish I could tpye...
