Re: Passat Front bearing - HUB centre Bolt
Scotty33 /Anyone please
I need to replace my Passat CV Boot and my Haynes manual tells me to reove gteh Hub bolt. Measuring unscientifically with a ruler, I estimate that I need either a 8 or 9mm Allen Key or some kind of "Male" socket. Does this makee sense / am I misssing something please ?
Also the manual says replace the HUB bolt with a new. Could I get by re-using the old one e.g. with some nut sealant glue ?
Re: The bolt, Yes, you can get allen key bits, to use with a breaker bar. I think mine was 14mm?
The bolt should be torqued to a nominal figure, then Angle tightened through a certain amount of degrees. I forget the figures, but the point is, it is a stretch bolt and there is a risk it could fail if it were re-used. The CV boot kit, may have a new one included?
