Re: RED brake warning light
top up the brake fluid reservoir, remove the cap and gently lift the gauze this will allow you to fill the level to max as the gauze can sometimes prevent the level from rising to max in the main chamber
the fault occurs when cornering as the fluid moves and at first glance the level appears ok but lifting the gauze allows the fluid level to drop
if it occurs when cranking the engine its often a sign of voltage drop at the battery and if the battery is ok there is a modification to bypass the dash warning light when cranking
this involves adding a relay for x relief
Cheers when i get home tonight thats the first thing i`ll do. A4 advant 1.9TDI quattro what brake fluid do i buy.....
