Replace injector loom in 2002 Golf TDi -ATD Engine Code - PD Engine ?
I've seem references to a posting on this site re: details of replacing the injector wiring loom on a PD engine. I've spent several hours searching and still can't find it ! Can anyone direct me specifically to the posting ?:zx11:
Many Thanks
Re: Replace injector loom in 2002 Golf TDi -ATD Engine Code - PD Engine ?
replacing the injector wiring loom is dead easy once you have the loom in your hand you'll see were it sits .you need to take the sound cover off then the rocker cover inside you will see the loom.any troubles drop me a line and i'll help you out
oli
Thanks Oli, If I was doing it at home I wouldn't be concerned, but traveling to it I don't want any unexpected problems e.g. not having the right tools with me.
Regards
You may find that you have to remove the EGR valve to gain access to one of the cover bolts.
Thank you both for your input. Successfully completed yesterday, much simpler than I had anticipated, and seems to have cured the problem. Only difficulty was getting access to the left rear 10mm rocker cover bolt-absolute pain as mentioned above! Interestingly, the connector to the faulty injector came away easily compared to the other three so suspect either faulty connector or someone had been there before ?
Thanks again
