In regards to my Broke a bolt thread, i started to drill it out only to snap the cobalt drill bit and for it to fall straight into the hole for the injector...bad luck i say. So basically i have given up trying to drill it out and i am going to get the head off take it to a garage and get it done properly!
While i have to head off, i have decided to go for a rebuild to make sure my engine is in tiptop condition. it has 227978 miles on it so it needs doing i guess.
I have order the following from GSF
Cambelt kit
Head gasket
Cylinder gasket kit
Thinking of geting new valves and valve springs while i am at it. Any thing else that is required or anything i can upgrade as i am thinking of bringing the power up quite alot as this car has just turned into a project. i am also thinking of gettin the head ported too.
So any help and advice is greatly welcomed, and if you are in the lincoln area you are more than welcome to pop by and lend a hand ;)
Cheers in advance
Rich
