Will 7x16" 5x112 steels with a 57.5mm Centre Bore diameter fit a 2006 B6 2.0 SE TDi Estate?
And will the wheel bolts used on the OEM standard alloys be the right size for the steels?
Printable View
Do you know what offset they are? Otherwise yes they will fit straight on. A fitment off that description sounds like they were originally for a VAG car.
As for bolts they should be grand!
Offset is 37
