As the title says,
I wouldn't think twice about rebuilding an engine so why not a turbo?
a set of instructions would be nice but, any one got some?
its a GT1749V 110bhp 2000 model.
Cheers.
Printable View
As the title says,
Cheers.
In comparison an engine is easy to rebuild compared to a turbo, simply because of one reason... a home DIY mechanic cannot balance a turbo correctly.
Its vital that the impeller is correctly balanced otherwise the turbo will eat itself within a short period of time.
That said i'm sure people have simply replaced their worn parts with a re-build kit and had many happy miles out of it however with such an important part of the engine and the knowledge of damage they cause when they fail i would highly recommend that you leave a rebuild to the professionals.
more info try google 'turbo balancing'
I may be able to help a little here.
As Swalker says, rebuilding with new bearing, etc. including balancing is probably best left to the professional outfits. There are quite a few and prices vary a lot, but you can get a service exchange on a quick turn around for reasonable money. Google away.
However, one of the favourite turbo jobs is to clear out the crud from a VVT turbo on a diesel model. which is dropping into limp mode due to turbo overboost. I don't know if your model is petrol or diesel, but assuming you have an oil burner then it is a fairly strightforward job for anyone who would confidently strip an engine.
Precise details vary but the principles are the same. There is a very detailed and clear set of instructions at tdiclub.com under the turbo101 section.
If that isn't enough, PM me and I will send you some more links and photos. I did an Audi 2.5 V6 TDI using the info available on the web.
My key tip is this - be very methodical, take photos and notes during disassembly and wear gloves otherwise you hands wil be black for a month. Oh, and make sure the oil feed isn't gunged up when you re-fit. Good luck!
