Just purchased a Hex-USB+CAN interface from Gendan automotive products a supplier for ross tech.
Downloaded software from ross tech, no problems, but got to this point and am now stuck,
Click on the Found New Hardware message and the Found New Hardware Wizard should start up.
If you are prompted with the choice, pick “No, Not This Time” when asked if you
want to connect to the Internet to search for drivers. Select "Install the software
automatically (Recommended)" then click
[Next >]
The process should be automated but you may need to click “Continue Anyway” part way through the process.
The hardware wizard starts correctly but doesn,t give the option to install the software automatically, it looks for drivers, but states none can be found.
I am running windows 7 starter on my laptop.
Last point, would i need to be connected to the car to eliminate the problem.
Anyway thanks for looking, and any help you may be able to give, i,ll carry on with the search button for now.
john
