Re: open door warningNot sure what to make of this.. this morning, the 'open door' warning light came on for the driver door. i double checked this a
Try disconnecting the battery. I have had similar lock troubles a couple or three times when I have recovered from a flat battery after leaving the coolbox plugged in. Disconnecting and reconnecting reset the CCM.
You need to look at 046 convenience control module. It should have logged a remote locking fault. As snapdragon says, a low voltage can cause this.
i specfically ran the 046 convenience control module. however that came back with no errors!
interestingly this morning, i noticed i am unable to unlock all doors from the remote, but then not able to lock anything via the remote.
i can lock all the doors via the central locking switch internally from the drivers door side panel (where all the controls for the windows are)
That suggests either the remote has packed up or the fault is the aerial connection to the ccm. The ccm won't report a fault if it never gets a signal.
