With this lovely cold weather the sliding doors of my T5 have frozen shut. Does any one have an easy fix for this apart from moving further south to warmer weather.
Allan
Printable View
Allan
Too late now but try putting some silicon lubricant on the rubber seals. Not a cast iron solution but it well help.
If you can get in the back you could try gentle heat from a hairdrier on the doorseals & if that works try potshot's preventative measure.
Hope this helps.
