I have a 1994 2.0 coupe.
The N/S window will not go up.
There is a click when I press either of the buttons but nothing else.
When I use the button on the O/S, the light on the N/S button goes out then on again when I let go.
Can anyone help?
Printable View
Can anyone help?
If it is only the passenger window failing, to me it seems likely to be a switch problem. It has happened on both of my coupes and swapping in a replacement switch cured it both times. It seems as if both switches need to be in good working order for either to work. If one fails they both seem to fail
This might help for removal:
https://www.vwaudiforum.co.uk/forum/s...ad.php?t=32863
At least while you are working on the door, you could whip the card off and carefully give the motor 12v direct to get it to close? Maybe test if there is some voltage coming through the loom. wires can break in the doorhinge area and relay failure is not uncommon
