vw polo mk3 starter motor problems HELP!!
hey there my starter motor failed so got a new one
and was told by kwik fit the starter engine should factory fit but it just slid into the gearbox
i was then told that there is ment to be a brass bearing that helps hold the start motor in place
after 3weeks it broke again
and they said they cant do anything all they did was fit a new starter motor
what should i do ?
can i get this repaired or should i get rid of my car while its running again :confused::confused::confused::confused:
Re: vw polo mk3 starter motor problems HELP!!
The brass bush in the bell housing has disintegrated and if the hole is gouged out bigger than original then the box has to be rebuilt with a new bell housing or a custom made sleeve fitted, all of which are expensive as the box has to come out. As for unloading your car on some poor unsuspecting innocent buyer, I cannot advise you on that as if I did something like that (being in the trade) I would be breaking the law…
Hey thanks for a fast reply
i really dont know what todo
kwik fit fitted for me and it lasted 3weeks
so i got a new one fitted today
i see u can buy gear boxes on ebay would it be worth my while buying one and getting it fitted?
or should i try trade my car in i really dont know what to do
could a mechanic repair this ? how much u think it would cost
thanks
Used boxes are a dangerous game, you may find one with a good starter bush but that is otherwise worn out. Of course a mechanic could repair it but it is not going to be cheap.
what ill do is ill phone locally places who deal with gearboxes
when i phone will i say that the he brass bush in the bell housing has disintegrated ?
if its a couple o hundred ill do it
as i like my vw only done 60k miles but r reg
done well on mot aswell
im so frustrated
thanks for your support
