Hi Guys ,
After advice on which oil is best for my diesel passat , i have a 55 plate 1.9 tdi 110bhp .
Thanks Mucker :biglaugh:
Printable View
Hi Guys ,
Great engine oil that hex
I expect your user manual suggests the use of any oil meeting VW specs 505.01 or 507.00, depending on whether you are on fixed or variable servicing.
Probably best not to use Asda's own brand 20 50
Thanks for replies will check manual for spec , Im new to the site and was after peoples prefered engine oils thats all . Preiously owned 53 plate passat and bought castrol semi synthetic diesel oil only later to be told by vag garage this was the wrong oil needed to be pd oil .
Thanks again;)
If it's a new shape Passat (PQ46) then it'll have either a BKC, BXE or BLS engine found in most of the VAG range.
1.9TDI 105PD
