Re: MK4 Air Con Saga & Fix
Cheers man, i was getting real paranoid about my Climatronic reading that! At least it is sorted now and does not cost the earth, there seem to be some well known problems with Climatronic but it is the first time i have heard that one.
I must admit I was highly dubious when the service manager called me to explain what they intended to do! That said, I had exhausted all of my ideas, so it seemed a logical path to try.
I have scoured this (and other VW) forums looking for possible answers to the problem, but no-one came up with that! Hence my reason for posting. Fortunately, the climatronic system seems to be behaving itself now - I don't want to think of the cost if the main control unit fails!
The joys of owning VAG - while they're running, they are lovely, it's when they stop that the bills start racking up! Bit like my old Lancia HPE, but that's another story.....
:beerchug:
Good to know about these hidden/undocumented 'features' and thanks for the write-up!
HI there,
I ve got a different problem ...my fans don t work and also the a/c don t think is working propery(i ve got a mk4 tdi with a/c not climatronic) meaning I turn it on and it s not getting as cool as it should be...now again I might need some gas inside but the weird thing is when i do output tests with vcds the radiator fan module does the job for a few seconds(the fans start to spin) and then stop but when the car is running none of the fans work ,not even with the a/c on or without.is the fans control module the one under the battery? I know that fans are a common problem on the mk4 but somehow it might be the same as yours...no a/c because fans don t work...
Any ideas?
Ths
Not sure about your problem being the same as mine, as mine wouldn't work with vcds on, even briefly! It is possible that you haven't enough gas charge to allow system to operate, or that the high or low pressure switches in the system (which prevent operation unless correct pressure is obtained) have failed.
My first task would be to have a reputable garage check the level of gas in the system (as this is easiest and cheapest) - should be between 720 and 790 grams (750 is usual). Any different and the system will not operate.
If all is well, then check compressor is working by putting 12v on the clutch connection with the engine running and a/c selected on, it should run briefly. If not, then it is signal from a/c control unit or fan module.
Hope you get it fixed soon.
The radiator fan control unit is bolted to a bracket on the left chassis leg under the battery and is not a common failure but failure of the large radiator fan is common. You can easily tell if the radiator fan/control is an issue with non-functioning A/C if it works when you are driving along but cuts out in traffic.
