Re: polo 95 distributor cap
update:
still having this problem of carbon build up on the cap and rotor after a few hundred miles. changed the coil today as seemed to be getting a short through the amplifier. strange because the car runs fine until the carbon builds up.
anyone any other suggestions as to what this might be. any help appreciated.
thanks
darren
It has electronic ignition so therefore no condenser. If you are having an excessive build up of carbon on the cap and rotor, it may be due to poor quality components and an excessive plug resistance. I suggest you fit new genuine plugs, leads cap and rotor and that should cure the problem.
Hi crasher,
Thanks for response:beerchug:.
Unfortunately I have already done this. I bought a genuine VW cap & rotor and expensive leads and new correct spec plugs. Still no difference. Will see if the coil fixes it. If not I'm stumped.
Darren
