  • stuart
    Page 201551 of 164 FirstFirst ... LastLast
  • Latest Poll
    Bazza1687
    Re: AC fault recirculation flap fault code B109207
    I fixed it! I had to take out the glove box could then see the recirculation flap which was closed. I removed the motor the flap opened on its own, must
    Bazza1687 Today, 05:35 PM Go to last post
    Re: A4 B7 Overheating issue diagnosed
    All hoses off, pressure wash and compressed air backflush, possible new radiator.
    Crasher Today, 03:27 PM Go to last post
    Re: Faults p2006 p2004 p2015
    I have just been through a sketch on an A4 with this, new manifold fitted by another garage, I said "fit one that isn't a pile of ****" so they
    Crasher Today, 03:24 PM Go to last post
    Re: Head gasket.
    You will need the cam to cam locking tool and crank pin.
    Crasher Today, 03:22 PM Go to last post
    Re: Measured Soot Mass
    Yes it is a calculated value even when it says measured, more of a guesstimate.
    Crasher Today, 03:21 PM Go to last post
    Re: Rear Door won't open from outside, pls help!
    The A4's are always more complex.
    Crasher Today, 03:20 PM Go to last post
    Re: Golf Mk4-Issue: 16825-EVAP Emission Control Sys Incorrect Flow
    The original code showed the valve to be open circuit or have a wiring fault.
    Crasher Today, 03:19 PM Go to last post
    bobfrankish
    Hi Everyone, good news and bad news. The overheating issue is definitely water pump failure, but unfortunately the impeller has completely disintegrated
    bobfrankish Today, 02:30 PM Go to last post
    crunchynutter
    Newbie-ish
    Morning all
    I've morphed here from the passat forum, had to let the old girl go after 17 years ownership.
    I think I know just about all
    crunchynutter Today, 11:12 AM Go to last post
    Flycatcher1
    Re: front wing corrosion
    Just an update, any advice appreciated.
    I did take the arch liner off already and took photos, I didnÂ’t think at the time to take the
    Flycatcher1 Today, 11:09 AM Go to last post
    bashman40
    Good Morning all, iv got a 2009 vw passat cc gt tdi 170 DSG and i keep getting these faults each time it rains then clears after a while is this the
    bashman40 Today, 04:24 AM Go to last post
    Finless
    Head gasket.
    My 2003 Avant B6 SE 2.4 petrol V6 developed a misfire and, after a visit to a mechanic, the computer said there was a problem with cylinder 5 and, after
    Finless Today, 04:13 AM Go to last post
    gareth23
    Not sure if this helps but I think its a calculated value using two pressure sensors compared to atmospheric pressure or one differential sensor, bigger
    gareth23 Yesterday, 07:41 PM Go to last post
    gareth23
    I had the same issue on my current A4 and taking the bowden cable out and getting some light oil in it fixed it. Its not a great design as the cable is
    gareth23 Yesterday, 07:35 PM Go to last post
    FrenchAudi
    Re: Speed limiters.
    The only speed limiter that would work around here is a sucking great anchor permanently fixed to the back end of every car.
    FrenchAudi Yesterday, 06:31 PM Go to last post
  • Recent Blog Posts
