  • stuart
    Page 201476 of 164 FirstFirst ... LastLast
  • Latest Poll
    wacky7791
    Oem P/N for rocker grommets V6 TDI
    Hi all can anyone help me with the OEM number for grommet number 5 in this pic?
    wacky7791 Today, 04:24 AM Go to last post
    Maverick7777
    Re: Dash Board Lit up like a Christmas Tree. Warning Lights?
    Sadly all the lights came back on. Could a single issue cause all the lights to come on? The car runs fine, then the lights may go out. Any ideas please?
    Maverick7777 Yesterday, 07:30 PM Go to last post
    Re: A4 B7 Overheating issue diagnosed
    Yes, like an irritating rash that won’t clear no matter how much emollient cream you rub into it.
    Crasher Yesterday, 07:18 PM Go to last post
    quattromark
    Backup Camera not working
    A few months ago I successfully retrofitted a backup camera in my C6 4f - found all the parts on ebay, cost around £300 in total, not including the loom
    quattromark Yesterday, 06:22 PM Go to last post
    gordyhse46
    SQ7 4.0 diesel High Pressure Fuel Pump Replacement
    Good after Guys,
    I have recently noticed that my 2018 SQ7 is getting hard to start, in terms of sometimes / randomly it takes a couple of
    gordyhse46 Yesterday, 06:13 PM Go to last post
    JonnyDarcy
    Battery Recommendation
    the battery on my Audi A6 (C6) Avant 3.0 TDI Le Mans 2011 has finally now completely died. Can anyone recommend a replacement? I'm likely
    JonnyDarcy Yesterday, 03:50 PM Go to last post
    FrenchToGerman
    Re: Fault codes, no boost Mk6 GTD
    Managed to figure out the wastegate actuator setup with a bit of research apparently when the wastegate rod is completely retracted voltage should be
    FrenchToGerman Yesterday, 12:42 PM Go to last post
    bobfrankish
    Hello again Crasher, still with us after all these years! Thanks for the reply. I've flushed as much as I can and just one chunk of plastic has come out.
    bobfrankish Yesterday, 12:41 AM Go to last post
    FrenchToGerman
    Realised I'd left the ambient air sensor unplugged so that code is now gone.
    Just have the 3
    P023800 - Turbocharger boost sensor
    FrenchToGerman 11-05-2024, 04:32 PM Go to last post
    bac2ba6
    Lights always on ?
    Hello there haven't been here for a while, got a bizarre problem passat 2010 2.0 tdi bluemotion with stop start , as soon as I turn the ignition on all
    bac2ba6 11-05-2024, 03:19 PM Go to last post
    Looks like a wiring fault
    Crasher 11-05-2024, 12:46 PM Go to last post
    TTTateca
    Re: knee Airbag igniter fault - short to ground
    Pin 43 and pin 44 are filtered to GND by a block capacitor, on the PCB, next to the input pins. One of the capacitors has failed and become a resistor
    TTTateca 11-05-2024, 07:54 AM Go to last post
    FrenchToGerman
    Hi guys,
    Have recently replaced the engine in a 62 Mk6 GTD with the CFGB engine.
    Engine running OK but getting no boost from
    FrenchToGerman 10-05-2024, 10:56 PM Go to last post
    Bazza1687
    Re: AC fault recirculation flap fault code B109207
    I fixed it! I had to take out the glove box could then see the recirculation flap which was closed. I removed the motor the flap opened on its own, must
    Bazza1687 10-05-2024, 05:35 PM Go to last post
    All hoses off, pressure wash and compressed air backflush, possible new radiator.
    Crasher 10-05-2024, 03:27 PM Go to last post
  • Recent Blog Posts
