  • stuart
    Page 201437 of 164 FirstFirst ... LastLast
  • Latest Poll
    gareth23
    Re: Adblue Fault, Now Won't Start
    The impression I get is that its no restart - if you dont stop the engine it will keep running, Audi would probably be liable if they programmed the Adblue
    gareth23 Yesterday, 09:28 PM Go to last post
    benmack
    Anyone know if I can do that again when the 35 miles expires?
    benmack Yesterday, 08:33 PM Go to last post
    rainon
    Re: Polo Mk 5 1.2 2013 - P0335 & P0336
    You must be thankful its a pretty rare thing
    Did you replace the affected harness? I imagine even if you dry off the connectors, the water
    rainon Yesterday, 06:08 PM Go to last post
    Hladd7
    VW Polo 18 Plate - Battery Drain from 5f Module Infotainment
    I was wondering whether someone could help me with some advice?
    I have a battery drain which, after VW diagnostics, has
    Hladd7 Yesterday, 05:03 PM Go to last post
    vw mk7 golf
    Re: MK7 Golf water ingress locations
    Heating ducts in the passenger floor of my mj7 golf, could they be causing some condensation on the floor ? I'm noticing that it is damp 😕
    vw mk7 golf Yesterday, 04:46 PM Go to last post
    I have seen coolant get into the wiring harness from temperature senders and especially electric water pumps, this passes through the wiring and up into
    Crasher Yesterday, 04:34 PM Go to last post
    Re: Golf 8 GTI progressive steering and DCC: “for 19 inch wheels”
    Too new for me but I would expect it would need at least some soft coding changes and possibly map changes. With how the Golf 8’s systems are locked
    Crasher Yesterday, 04:25 PM Go to last post
    Pbro
    Hi , I picked up a Mk8 GTI yesterday.
    (I know the mk8.5 is round the corner but I needed one now and I liked the Mk8 despite its infotainment
    Pbro Yesterday, 02:54 PM Go to last post
    rainon
    Update - The car went in this week for diagnosis and I had an interesting update from my friend (the cars owner). They did find a problem with the wiring
    rainon Yesterday, 01:57 PM Go to last post
    The SCR lock is a safety feature to prevent fire. I am going to have to be harsh here and ask WHY you went on holiday with that warning?
    Crasher Yesterday, 12:55 PM Go to last post
    Re: Boost pressure sensor MAP good brand replacement?
    I would fit a new Bosch sensor first, bit of an **** to get at, and then the repair harness if the code returns and this only applies if it is an open/short
    Crasher Yesterday, 12:48 PM Go to last post
    Re: CRLB engine alternative
    I would need to be at work to look at this so remind me Monday with your VIN and if possible, the VIN of the donor vehicle.
    Crasher Yesterday, 12:45 PM Go to last post
    Re: A6 2002 2.5 TDI - won't start
    No, please, not him… notorious in the Notts Derby area.
    Crasher Yesterday, 12:43 PM Go to last post
    Re: Touran 2.0TDI BMN cranks, no start
    Good luck.
    Crasher Yesterday, 12:41 PM Go to last post
    benmack
    Brief update, I reset IDE04567 Resetting of SCR tank level detection and IDE04730 Reset SCR lock, as per this post
    Best way to reset AdBlue (level
    benmack Yesterday, 12:08 PM Go to last post
  • Recent Blog Posts
