Page 1 of 33 12311 ... LastLast
Threads 1 to 20 of 660
Announcement
Announcement Announcement: **IMPORTANT** Please support VW Audi Forum - Donations
stuart (- Founder -)
05-07-2020
Views: 153,205 View Announcement
Announcement Announcement: **IMPORTANT** Free Email Accounts
19-01-2018
Views: 302,432 View Announcement
Announcement Announcement: **IMPORTANT** Site Sponsors
17-10-2008
Views: 289,648 View Announcement
Forum: Audi A5 - B8 Forum - 2007 - 2016
  Rating Title / Thread Starter Replies / Views Last Post ByReverse Sort Order
Audi A5 2.0 cr tdi, Non start, No Codes
Started by jim potter, 30-03-2024 07:31 PM
03-04-2024, 12:56 PM Go to last post
Complete equipment check based on VIN
Started by S5AudiS5, 08-01-2024 11:25 PM
08-01-2024, 11:25 PM Go to last post
Lightbulb
a5 3.0 Door seals
Started by yo_dymo, 08-01-2024 05:15 PM
door seal, whistle
08-01-2024, 05:15 PM Go to last post
EGR pipe 2.0tdi CGLC quattro engine
Started by benali10, 23-11-2023 02:52 PM
23-11-2023, 02:52 PM Go to last post
22-11-2023, 05:05 PM Go to last post
Front Upper Control arms
Started by shabazmo, 21-11-2023 11:38 PM
22-11-2023, 05:03 PM Go to last post
A5 2008 3.0 tdi egr delete (CAPA engine)
Started by Nafe05, 28-09-2023 11:33 AM
28-09-2023, 02:33 PM Go to last post
DPF issues in A5 2008 2.7l TDI Multitronic
Started by 3lusive, 10-09-2023 05:35 PM
dpf particle filter a5
12-09-2023, 12:29 PM Go to last post
Weird safety pin on gearbox shaft rotor
Started by Sergiu_zee, 24-08-2023 03:49 PM
28-08-2023, 01:28 PM Go to last post
Occasionally Kangarooing
Started by Ben B, 24-11-2021 09:28 AM
09-06-2023, 01:27 PM Go to last post
Low Brake Pad Warning Light
Started by johnnywishbone1, 10-04-2023 10:55 PM
11-04-2023, 04:14 PM Go to last post
Knocking noise when releasing accelerator
Started by S5AudiS5, 29-03-2023 10:09 PM
03-04-2023, 10:06 PM Go to last post
Exclamation
A5 Convertible - Leaks everywhere!
Started by The_IMF, 18-03-2023 10:39 PM
20-03-2023, 10:11 PM Go to last post
Cam follower for high pressure fuel pump
Started by rhencullen1989, 15-01-2023 10:10 PM
30-01-2023, 09:24 PM Go to last post
Engine oil spec
Started by fourringsrus, 11-01-2023 07:20 PM
11-01-2023, 07:20 PM Go to last post
Plastic sump plug....special tool needed?
Started by rhencullen1989, 22-07-2022 06:38 PM
25-07-2022, 10:36 PM Go to last post
Air filter too big
Started by rhencullen1989, 23-07-2022 11:13 PM
25-07-2022, 10:09 PM Go to last post
TFSI oil change 5W30 or 5W40
Started by rhencullen1989, 20-07-2022 07:21 PM
25-07-2022, 10:04 PM Go to last post
Replaced folding mirror - not folding
Started by b3nb123, 19-07-2022 08:50 AM
19-07-2022, 05:38 PM Go to last post
Oil change
Started by rhencullen1989, 01-04-2022 04:48 PM
01-04-2022, 06:41 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
