Thread: 2.5TDi Needle Lift Sensor
  1. Thumbs up 2.5TDi Needle Lift Sensor
    May 2007
    Hi, sorry to sound like a complete numpty - I'll say first I'm no mechanic, but...
    I've had some problems with performance with my 2002 2.5TDi Quattro, so I bought a VAG-COM cable off ebay.
    Got the software and cable working fine, and the diags say:
    00542 - Needle lift Sensor (G80)
    30-10 - Open or Short to B+ - Intermittent
    Done some research - it appears I need a new injector #3 with needle lift sensor fitting, or the wiring is dodgy.
    Had a look under the plastic shield, but can't find the injector with above said Needle Lift Sensor - can anyone provide me with a picture and big numpty arrow pointing to the injector and cable on the B6 2.5 TDi engine??
    Thanks in advance...
    Canada
    This diagram should help
    If you want a better look sign up to this site www.vagcat.com
    Rob
    May 2007
    Cheers mate, back left (I'm sure I looked there and couldn't see any wiring coming off, but will persevere...)
    london/ UK
    You will need to remove the rocker cover to access the injectors...
    May 2007
    Hi, have removed plastic rocker cover, and examined all injectors but they all look absolutely identical - none have extra wires for the needle lift sensor!
    Should the sensor wiring be visible on a 2002 A4 2.5 TDi engine (B6 8E model)???
  6. Re: 2.5TDi Needle Lift Sensor
    london/ UK
    Remove LH(driver side) rocker cover and is there. If you look closelly, there is a small wire on the side of the rocker cover going inside the head.
  7. Re: 2.5TDi Needle Lift Sensor
    Jan 2009
    Bournemouth
    Is a needle lift sensor a genuine part or does anyone know where to get one
  1. A6 2.5tdi Cv Joint
    By lee@carparts in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-07-2007, 10:45 AM
  2. Thrust Sensor same as Map Sensor?
    By whistleblower in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-05-2007, 06:03 PM
  3. 1.9tdi v 2.5tdi
    By davegilsenan in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-01-2007, 12:21 AM
  4. VW TRANSPORTER 2.5TDI
    By stankeeler in forum The Commercial Range
    Last Post: 17-11-2006, 03:31 PM
  5. VW TRANSPORTER 2.5TDI
    By DICKO in forum The Commercial Range
    Last Post: 26-10-2006, 08:59 PM
