Thread: SDHC Cards working!
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
  1. Talking SDHC Cards working!
    Some good news folks...
    My Audi A4 B8 went in to the garage this afternoon for a software update to correct a problem with the traffic information programme on the concert radio (MMI low) (the radio was not remembering the volume I had set for the traffic information updates).
    As a result, my hardware / software combo which was H11 and SW0130, has now been upgraded to H11 and SW0310.
    More importantly, I have just checked and my 8GB Transcend SDHC card is now finally working fine in the radio!!!
    My car is one of the first production models (built in September 07) so clearly this upgrade does not need new Concert Radio hardware.
    Some follow-up research on the internet this afternoon suggests that the SDHC functionality was introduced as from Software version 0310, so you may wish to check your own versions of the MMI and see whether you can get your dealer to do the update.
    I will be ordering a 32GB SDHC card shortly and will post back the results.
  2. Re: SDHC Cards working!
    Jan 2009
    Essex
    There's been a lot of reports of the cards working but the question is can you access everything on the card.
    e.g. if you load the card up, can you access all the tracks as previously people have found they can only access the first couple of Gigs worth.
    MY2010 A4 Avant 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Full Leather, B & O, 3G Tech Pack, Adaptive Lights, Dynamic Susp, Folding Mirrors, Power tailgate, Storage/Light Packs, Parking Plus, Heated Seats, Rear Blinds, Load Rails, Privacy Glass, Rear Airbags, TPMS, Load Liner
    Gone : 09 A4 Avant, B6 S4, TT, Golf GTi...and the rest are embarassing!
  3. Re: SDHC Cards working!
    Loaded up my 8Gb SDHC card this evening with about 5 gig of files (about 700 files) and all seemed to be working ok, with no files obviously missing.
  4. Re: SDHC Cards working!
    From reading around it seems that 4,000 files is the new limit. Haven't been able to test this yet, but sounds like more than enough for my usage.
  5. Re: SDHC Cards working!
    Quote Originally Posted by nickhx View Post
    You might be able to see them all but when you try and play some of them the track name could turn grey and say that the file is corrupt (even though it's fine when you play direct off the card on a PC). Have you tried a large number of the tracks on your card?
    What I've noticed is that if I remove some of the working tracks suddenly some of the previously "corrupt" track start working. So as said above it doesn't seem as if it's a size of card compatability issue in terms of reading it but rather it will only play up to a certain volume of files.
  6. Re: SDHC Cards working!
    Actually scrap that, I've just realised that the tracks don't work are nearly all mp4s rather than mp3s. Very odd especially as some work but others don't. I'll try converting them to mp3 and will let you know how I get on.
  7. Re: SDHC Cards working!
    You could also try formatting the card with Panasonic's special SD card formatter program (assuming you have got Windows) which you can google for.
    I have read elsewhere that this can solve the problem of missing files (apparently Windows own formatting is not 100% compliant with the SD card format!)
  8. Re: SDHC Cards working!
    Aug 2009
    United States
    Any idea on how they were able to upgrade the firmware of the head unit? where do they connect, software they use? etc? I have spoken to Audi NA and they insist that it is impossible to upgrade the firmware...
  9. Re: SDHC Cards working!
    AFAIK, only the dealer can perform the update to the Concert Radio Software if it is MMI low via the head unit.
    However, if you specifically ask for the software update to enable SDHC, nothing will be available as Audi do not consider it to be an "issue", as the original specification for the A4 Concert was only to read up to 2GB cards.
    So, the only way to get the upgrade is to ask your dealer to repair the issue with the traffic volume (see my first post above) which should be done under warranty. That fix involves updating your MMI software to version 0310, which also as a helpful by-product, enables your Concert radio for SDHC!
  10. Re: SDHC Cards working!
    Jul 2009
    Bristol UK
    ...the only way to get the upgrade is to ask your dealer to repair the issue with the traffic volume (see my first post above) which should be done under warranty. That fix involves updating your MMI software to version 0310, which also as a helpful by-product, enables your Concert radio for SDHC!
    Doesn't affect me, but that is the kind of collaboration that really makes me appreciate forums A fantastic tip.
    A4 (B8) 2010MY - 2.0TDi 143 SE Executive Avant; Sphere Blue Metallic, Audi Music Interface, Electric Lumbar Support, Heated Front Seats, Interior Light Pack.
    Now: Octavia Mk3 2.0TDi Elegance Combi, Steel Grey, Full Ivory Leather, Columbus 8" SatNav, Winter Pack, KESSY
  1. SD card capacity?
    By nsr300 in forum Tiguan
    Last Post: 29-06-2012, 08:34 AM
  2. SD cards on 510 head unit
    By maisbitt in forum Scirocco - 2008-
    Last Post: 20-12-2009, 10:47 PM
  3. Trailer Turn Signals Not Working - but Trailer not Connected
    By tidybutt in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 07-05-2009, 09:24 PM
  4. SD cards to use in Audi A4 DVD Sat Nav
    By IainP in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2008, 02:24 PM
  5. Near SIde Main Beam STopped Working
    By markb1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2007, 10:21 AM
