Thread: Audi 80 1.9Tdi 90hp 1Z VS 1.9Tdi 110hp. NOISE issue...
Results 1 to 10 of 14
  1. Audi 80 1.9Tdi 90hp 1Z VS 1.9Tdi 110hp. NOISE issue...
    Feb 2007
    Hi.
    I have 2 cars at the moment. One is a Seat Ibiza with the 1.9Tdi AFN 110hp engine. The turbo is a VNT15/17.
    The other is an Audi 80 1.9Tdi 90hp Avant, 1Z engine. The turbo is a GT15.
    Well, keeping the turbo issues apart from the discussion... does any one know why the audi engine a lot noisier than the 110hp ?
    Neither of them has an engine cover. The Seat 110hp has a "normal" diesel engine noise, and doesn´t produce hesitations/vibrations....
    But in the Audi, i can hear easily the " clak clak clak tak tak tak " noise while operating, and produces a lot more vibrations in specific revs (specially the lower ones).
    Any ideias on this? I´ve thought on the Injector Pump timing may be too advanced in the Audi , has it´s value in Vag.com is 78 !
    But, may the valves ? Or the cam followers or lifters? I heard that damaged lifters may produce this kind of noise.
    I´ve also made a comparison bettween them, with the hood open , and working at the same time.
    Even the engine code is the same in both engine (serial number near the 3rd injector).
    Injection pumps may be different, but i believe they´re both Bosch VP37 and dont think that it would make that big difference about the noise issue. They´re both direct injection.
    Thanks!
    Apr 2007
    Lancashire
    Apart from the fact that the Audi 80 engine is probably older than the Seat 110, one of the main noise issues with the VAG direct injection engine can be worn 'hydraulic lifters', or even worn injectors.
    My A4 TDI 110 sounds like a tractor.
    Feb 2007
    many thanks for your reply.
    Well, my injectors are almost new and were cleaned. They are PP502 nozzles in 110hp injector body! Have tried them before in other car and are in good condition.
    I really suspect that the hydraulic lifters can be really worn. Hope the valves and cam are ok.
    As you say, the car sounds like a tractor. Better, it sounds like an OLD non-turbo Diesel Engine . I think you know what i mean. It sounds and "feels" like it when you drive it, because you feel the vibrations in the car and the sound is so like it.
    What else could it be? I dont think it´s the injector pump. The car "works" fine and the idle is stable. Even the vag-com value for the timing (78), i dont think it justifies what i am complaining about.
    cheers
    Quote Originally Posted by ini View Post
    Mar 2007
    northumberland
    Are both cars using the same oil? are the nozzles the pp520 frantelli bosio ones if so do you know where you can get them from as ive been looking for some.
    Feb 2007
    I am using Mobil super S for turbodiesel 10w40. The car is 182.000km , and i have no idea if they are real. I have no reason to say yes, neither to say no...
    About the nozzles, they came from my other car. The model is PP502 , not PP520. I am not sure where to get them, but isn´t there a webpage?
    You can to this forum : http://www.ibizaclubpt.com/forum/showthread.php?t=16355
    Have a word with the user "fbau". I think he can tell you more about it.
    Ps - Sorry about mentioning other forums, just wanted to help.
    Any more ideias about what can cause this horrible tractor noise in my engine? Anything in the combustion chamber?
    cheers
    Quote Originally Posted by Stevef. View Post
    Mar 2007
    northumberland
    Hello again, I had a petrol 205 gti about 10 years ago with worn big end bearings that sounded like a diesel.
    Feb 2007
    hmm, i hope that´s not my case
    Thanks for you reply.
    Anyone else has a clue about it?
    cheers
  8. Re: Audi 80 1.9Tdi 90hp 1Z VS 1.9Tdi 110hp. NOISE issue...
    Mar 2007
    U-96
    Not absolutely sure, but I thought that the 110 BHP AFN, had higher injector pressures than the 90 BHP 1Z ? I believe
    Higher Injector pressures should ;
    • Increase fuel atomisation
    • Lower emissions
    • Improve power
    • Decrease noise
    No, just checked 1Z and AFN both have 190 Bar opening pressures. So it's not that !
    But there are lots of other factors, including one of your suspects ... the timing.
    TR7
  9. Re: Audi 80 1.9Tdi 90hp 1Z VS 1.9Tdi 110hp. NOISE issue...
    Apr 2007
    Lancashire
    On that note, one of the cars is running 'very large' 0.232 PP502 nozzles, and has much more fueling at all revs (probably the Audi).
    The other car is presumably running standard 0.184's.
  10. Re: Audi 80 1.9Tdi 90hp 1Z VS 1.9Tdi 110hp. NOISE issue...
    Mar 2008
    hello all
    im looking through all the forums to try and identify a similar range of probs as me!
    I have currently 2 mk3 golf tdis one is m plate 140k on the clock the other is mk3 80k. My older car is quieter from the top end, less tapping and clattering, sounds like something is a bit flappy and loose on the lower mileage car. Its a mechanical tapping, not a knocking or thudding (eg, pipes on bodywork, loose covers, etc.).
    I have had the flashing glow plug light and had its ecu diagnosed today, needle sensor issue.
    Most of the probs i am having, noise, ecu light, bad economy, low boost, crap power are linked to an issue with this injector/sensor on quite a few threads on this forum.
    So maybe get that checked out? - should be a fault logged on the ecu.
  1. Audi a4 1.9tdi 90bhp
    By srf in forum Archive posts
    Last Post: 13-06-2007, 02:26 AM
  2. Audi A4 1.9TDI Can't open the bonnet
    By strongbull in forum Audi A4 - Archive Topics
    Last Post: 06-06-2007, 02:10 AM
  3. Audi A6 Avant 1.9TDI 115 se without CD!!!!
    By crashball75 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-04-2007, 03:48 PM
  4. Audi A4 1.9tdi starting problems
    By sudderz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-11-2006, 07:26 PM
  5. 1.9TDi 130 Sport Exhaust/Heat shield noise
    By landon in forum Passat - Archive Topics
    Last Post: 14-08-2006, 07:56 PM
