Thread: polo climatic problems
  1. polo climatic problems
    Feb 2007
    I've been getting the codes below so bought a heater temp flap motor (V68) and a fan resistor pack as speeds 1 & 2 were not working but the V68 seems to be either in the full hot or cold position and doesn't regulate in between.
    Do i need to perform basic settings or adaptation in VCDS or am i looking at a new heater switch/dial?
    Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
    Part No: 6Q0 820 045
    Component: Klimaanlage X0840
    8 Faults Found:
    01271 - Positioning Motor for Temperature Flap (V68)
    30-10 - Open or Short to Plus - Intermittent
    01596 - Motor for Outside/Recirculated Air Flap (V154)
    29-10 - Short to Ground - Intermittent
    28-10 - Short to Plus - Intermittent
    55-00 - Adaptation Not Successful
    41-10 - Blocked or No Voltage - Intermittent
    __________________
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  2. Re: polo climatic problems
    Nov 2008
    folkestone.kent
    basic setting needs to be done
  3. Re: polo climatic problems
    Sep 2009
    Slovenia
    @VAGMAN54:
    I found this thread (one of rare about this V68 error). I don't have Audi but I still hope that you could help me.
    I'm getting this V68 error on my VW Polo 2003y and symptoms are: when temperature is set to minimum or maximum everything is OK but when not car heats cabine some period of time normally and then it starts heating maximally. Sometimes it's not hapenning, sometimes it happends after 5 seconds. Shortly, it's periodical error.
    Somewhere I found that there can be two kind of V68 errors:
    - 01271 actuator for temperature flap -V68
    - 00600 potentiometers -G92 in the actuator -V68 (for temperature flap)
    I don't know which one is mine but I can find out.
    What do you think?
    Thanks in advance
  4. Re: polo climatic problems
    Nov 2008
    folkestone.kent
    it will be the acuator that works the flap,replace the unit install basic settings and it will work as it should.........
  5. Re: polo climatic problems
    Sep 2009
    Slovenia
    Thank you for a fast answer, I'll do it that way.
    Best regards,
    Miljan
  1. 2000 model Polo starting problems
    By Mr S.A. in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2008, 01:42 PM
  2. Zero Vehicle Excise Duty On Volkswagen Polo Bluemotion
    Last Post: 20-07-2007, 10:30 PM
  3. Polo Marks The Uk Debut Of Bluemotion
    Last Post: 12-02-2007, 08:40 PM
  4. Replies: 0
    Last Post: 11-02-2006, 09:08 PM
  5. Replies: 0
    Last Post: 23-05-2005, 07:37 PM
