Thread: At last! A uk recall for the passat brake failure water leaks plenum chamber
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
  1. At last! A uk recall for the passat brake failure water leaks plenum chamber
    Jun 2006
    UK, Mids
    I received a letter from VW today.
    They got my details from DVLA, as my name has DVLA's spelling mistake.
    It is about a recall for my 2002 MY Passat.
    A bit late, but may help me get a refund or partial refund for the damage this caused, rather than the denial.
    Has anyone else got one?
    I have posted it as text rather than a scan so that it come up in searches.
    Volkswagen (UK) . Yeomans Drive· Blakelands . Milton Keynes MK14 SAN
    27 March 2009
    VGS151 88/1/001 (edited - scanner software made a mistake - thanks westie)
    Registration no XXXXXXXX
    Chassis no 38XXXXXXXXXXXXXX
    SERVICE ACTION - VOLKSWAGEN PASSAT
    Possible water ingress
    Dear Sir or Madam
    We have identified that some Passats could have clogged plenum chamber
    water drains, which may cause water to leak into the passenger compartment
    and the brake servo unit. To ensure your car's plenum chamber drain is clear,
    we recommend that you visit a Volkswagen Retailer to have it checked. This
    check will be completed free of charge.
    We strongly advise that you take up this offer to avoid possible water ingress.
    and consequential damage to your vehicle. The Retailer will inspect, clean
    and, if necessary, modify the plenum chamber on your car.
    Once your Passat has been checked, you should continue to have it serviced at
    the intervals recommended by the manufacturer. The plenum chamber drains
    are checked for blockages caused by debris (eg fallen leaves from trees} as
    part of the Volkswagen service schedule.
    Your nearest Volkswagen Retailer can be found online at
    www.volkswagen.co.uk or by contacting 0800333666. The check will take
    approximately half an hour, depending on circumstances. The Retailer will be
    prepared for your visit and able to answer any questions you have about the
    service check.
    Telephone 01908 601601
    Fax 01908 663936
    Customer Services 0800 0833914
    www.volkswagen .co .uk
    Volkswogen (UK) is a division
    of Volkswagen Group United
    Kingdom Limited
    A wholly owned subsidiary of
    Volkswagen AG
    Registered Offic e , As above
    Audi A8 - 2015 - 3.0TDI
    3 0 0
  2. Re: At last! A uk recall for the passat waterworks
    Oct 2005
    So I drive along to a VW dealership and they'll do this for me, no questions?
  3. Re: At last! A uk recall for the passat waterworks
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by snapdragon View Post
    water drains, which may cause water to leak into the passenger compartmentand the brake servo unit.
    Some Passats, not all 3B Passats??
    Yes, and they're really going to know about an 8 1/2 yo car......
    Nothing to see here, move along..
  4. Re: At last! A uk recall for the passat brake failure water leaks plenum chamber
    Mar 2008
    Just Cumbria now.
    Oh, and of course Audi and Skoda are going to follow for the A4s, A6s and Superbs which are also affected.....Emoticon.jpg
  5. Re: At last! A uk recall for the passat waterworks
    Oct 2005
    Quote Originally Posted by Hex69 View Post
    There goes my bubble :lol:
    Me, 3BG, 2001 - 8 years old too. Oh well <sigh>
  6. Re: At last! A uk recall for the passat brake failure water leaks plenum chamber
    Tyldesley, Manchester, UK
    Quote Originally Posted by volkswagen
    S'pose a one off check is better than a kick in the teeth. Mine needs a service and as part of it I was going to check the plenum. Maybe I should just take it to VW
    One German, Two Italian.
  7. Re: At last! A uk recall for the passat brake failure water leaks plenum chamber
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by MalcQV View Post
    "Thank you, Sir, we've checked your plenum chamber and that's all ok, however we've found x, y, and z and this will cost you £££££'s to recify. Please hand over your wallet and all your worldly goods....".
  8. Re: At last! A uk recall for the passat brake failure water leaks plenum chamber
    Jun 2006
    UK, Mids
    Mine is October 2001 (2002MY) and hasn't been to the dealer for a few years.
    It looks as though they got my details from DVLA/Capita as their Indian data inputters misspelled my surname for a random array of letters when I registered myself as a new owner. This means they must have asked DVLA for details of all cars' owners between certain VIN numbers or years.
    I hope you all get one, it sounds as though they modify the drains.
  9. Re: At last! A uk recall for the passat brake failure water leaks plenum chamber
    Oct 2005
    The modification is to poke out the rubber bung - same thing I did about two years ago
  10. Re: At last! A uk recall for the passat brake failure water leaks plenum chamber
    westie383 Guest
    I've just had my 2001 Passat in for the plenum chamber recall today, and to be honest it was a waste of time in my opinion. I did ask the girl on reception if they would put something in the service book to record the inspection being done, but as you never get to see the guy who does the inspection, I might as well of been talking to the wall. It would be interesting to know what they would do if damage had been done and discovered - as in the many posts on this forum, and how much VW would spend on repairs? Thanks to the VWAUDI forum, and others people's experiences, I've made it a point to clean out the plenum chamber twice a year with warm soapy water and an old tooth brush. Might seem a bit OTT, but better safe than sorry..
  1. US Passat Recall?
    By davey_g23 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-04-2008, 08:07 PM
  2. Replies: 0
    Last Post: 15-01-2008, 09:05 PM
  3. Some advice please needed on wheel offsets - ET37 vs ET35
    By Staz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2007, 05:48 PM
  4. Replies: 0
    Last Post: 10-11-2007, 08:05 PM
  5. The Passat Bluemotion – Uk Market Information
    Last Post: 02-05-2007, 07:28 PM
