Thread: VAG COM Ross-Tech Shareware v Unlocked
Results 1 to 10 of 12
  1. VAG COM Ross-Tech Shareware v Unlocked
    May 2008
    Bought a cable and using the shareware version, however only error code I have is
    00542 - Needle lift Sensor (G80)
    But if I had the unlocked version would it pick up more fault codes? or what else would it tell me?
    TIA
  2. Re: VAG COM Ross-Tech Shareware v Unlocked
    May 2008
    2001 A6 2.5TDI Quattro
    £14 cable off ebay and VAG Com 409.1 -US
  3. Re: VAG COM Ross-Tech Shareware v Unlocked
    134 Post(s)
    2025 Post(s)
    409 v 805, no contest. Pay the £260 for a proper LEGAL cable and get regular updates and a tool only a few steps behind VAG’s own VAS 5052a which costs £6k.
  4. Re: VAG COM Ross-Tech Shareware v Unlocked
    May 2008
    This is a list of the fault codes which made me think maybe some are not decoded:
    3 Faults Found:
    30-10 - Open or Short to B+ - Intermittent
    00523 - Shareware Version. To Decode all DTCs
    30-00 - Please Register/Activate
    00575 - Shareware Version. To Decode all DTCs
    08-10 - Please Register/Activate – Intermittent
  5. Re: VAG COM Ross-Tech Shareware v Unlocked
    134 Post(s)
    2025 Post(s)
    00542 Needle lift sender G80, Open circuit/short to positive
    (Glow period warning lamp flashes) This fault message is stored if the voltage of the signal from the needle lift sender is greater than 0.6 V.
    Possible causes
    1) G80 defective
    2) Open circuit or short circuit to G80
    00523 Intake air temperature sender G42
    Two versions
    1) Short to earth
    This fault message is stored if the voltage of the signal from the intake air temperature sender is less than 0.4 V.
    a) G42- defective
    b) Short to earth in wiring
    2) Open circuit/short to positive
    This fault message is stored if the voltage of the signal from the intake air temperature sender is greater than 4.7 V.
    a) G42- defective
    b) Open circuit or short to positive in wiring
    00575 Intake manifold pressure
    Two versions
    1) Regulating limit not reached
    This fault message is stored if the measured charge pressure is 800 mbar lower than the specified value for about 4 seconds above a certain engine speed and injection quantity.
    a) Hoses not connected, wrongly connected, blocked or leaking
    b) Turbocharger defective
    2) Regulating limit exceeded
    This fault message is stored if the measured charge pressure is 200 mbar higher than the specified value for about 4 seconds above a certain engine speed and injection quantity.
    a) Charge pressure control solenoid valve -N75- defective
    b) Turbocharger defective (charge pressure control mechanism sticking)
  6. Re: VAG COM Ross-Tech Shareware v Unlocked
    May 2008
    Big thx for replies crasher, also found this on the ross site which explains the differences between shareware and licensed.
    http://www.ross-tech.com/vag-com/vag-functions.html
    Suppose what it means is that it will display all error codes but not give a detailed explanation with shareware, which gives me some relief that I dont have a car with a catalogue of issues.
  7. Re: VAG COM Ross-Tech Shareware v Unlocked
    yorkshire
    wheres the best place to buy genuine cable,if ross tech what will the import tax cost
  8. Re: VAG COM Ross-Tech Shareware v Unlocked
    134 Post(s)
    2025 Post(s)
  9. Re: VAG COM Ross-Tech Shareware v Unlocked
    Ambler, PA, USA
    Quote Originally Posted by davidfbmw View Post
    From any of our UK distributors
    I believe our UK customers pay the queen 17% or there abouts.
  10. Re: VAG COM Ross-Tech Shareware v Unlocked
    134 Post(s)
    2025 Post(s)
    Ilexa are a UK distributor and where I buy my cables from.
    By the way, we don’t pay our taxes to the Queen; it goes to Gordon the Moron’s (our Prime Minister) government for them to waste on stupid things like bailing out banks that have been greedy.
  1. Latest vag com - From Ross Tech
    By Joshua in forum VCDS - General Questions
    Last Post: 26-01-2010, 11:54 PM
  2. Which software do i download from ross tech?
    By spence_star in forum Audi A3 - Archive Topics
    Last Post: 23-04-2008, 03:41 PM
  3. Which software do i download from ross tech?
    By spence_star in forum VCDS - General Questions
    Last Post: 13-04-2008, 12:30 AM
