Thread: VAG-COM/OBD Port locations
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. VAG-COM/OBD Port locations
    Oct 2005
    I've seen a lot of posts recently asking where to find the ports on various cars.
    This information is well documented by the creators of VAG-COM, Ross-Tech.
    Ross-Tech Vehicle Application Charts
    As an example, I have a Passat.
    So I click on the above link, select "VW Passat", scroll to the foot of the page and find that my port is either here;
    or here;
    Simple!
    6 1 1
  2. Re: VAG-COM/OBD Port locations
    Bristol
    they have every car except the Sharan .
    So if anyone is after its location , its under the ashtray in the centre console.
  3. Re: VAG-COM/OBD Port locations
    Canada
    Port for Skoda Octavia mk 1 is in the front under the steering wheel slightly to the left .
    Port for the Skoda Octavia Mk 2 is in the front under the steering wheel to the right near the door (Difficult to spot)
  4. Re: VAG-COM/OBD Port locations
    Quote Originally Posted by cbrpaul View Post
    This is for the MK1 Sharan, Galaxy & Alhambra
    The MK2 Sharan Galaxy and Alhambra is located underneath the bottom of the dashboard, in line with the fuse box access panel on the driver's side of the car. Stick your head under the dashboard and you will see the pink connector
    Paul
  5. Re: VAG-COM/OBD Port locations
    yorkshire
    where is the port on a 2005 a4 b6cab
  6. Re: VAG-COM/OBD Port locations
    Canada
    Quote Originally Posted by davidfbmw View Post
    On the older B5 A4 it in the passenger ashtray
    One rule of thumb is that EU regs state is needs to be accessible from the drivers seat, common place is in the drivers foot well
  7. Re: VAG-COM/OBD Port locations
    Jul 2008
    Just thought i'd add some i have scanned this week.
    2000 VW Golf 2.8 4 motion =behind detachable cover in front of ash tray on centre consol
    2001 VW Polo SDI 1.9 = under ash tray in front of gear lever
    2001 Audi A4 Avant 1.9tdi =under rear ash tray at back of centre consol
    1996 VW Golf 1.9 TDI below radio next to ash tray which you remove and slide the panel over
    Moderator edit - all those are listed in the first link
  8. Re: VAG-COM/OBD Port locations
    Aug 2008
    2008 leon 1.9 tdi 105bhp model ?
    andy
  9. Re: VAG-COM/OBD Port locations
    Canada
    Quote Originally Posted by onzarob View Post
    Quote Originally Posted by 4ndyleon View Post
    andy
    I would say in a similiar posistion as above, they can be hard to spot
  10. Re: VAG-COM/OBD Port locations
    1992 Audi 80 B4 - fuse box in engine bay (just under windsceen wipers when bonnet is up)
  1. Vagcom/VCDS User Locations
    By Col in forum VCDS - Users Locations
    Last Post: 05-04-2025, 07:00 PM
  2. OBD Port
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2010, 02:33 PM
  3. Whos the best garage? Post your locations and thoughts
    By Kev2904 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-02-2007, 02:24 PM
  4. Vag Com Port
    By Sharky_82 in forum Audi A4 - Archive Topics
    Last Post: 31-01-2007, 09:06 AM
  5. USB port
    By TheDufster in forum Passat - Archive Topics
    Last Post: 04-01-2007, 01:23 PM
