Thread: Indicators Blowing Fuses
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. Angry Indicators Blowing Fuses
    Sep 2007
    Recently had a problem with the indicators failing to work
    Quote Originally Posted by Irri_Tant View Post
    Indicators stopped working this morning on the way home from work. Hazards work though.
    UPDATE
    Replace the hazard relay about a month back (09-06-2008) with part from VW specialist
    Failed again this morning both left & right turn and also hazards have stopped working
    Located 10 & 15 amp fuses and replaced both
    Tried right turn and it worked
    Tried left turn and blew a 10 amp fuse
    Tried hazards and blew 15 amp fuse
    Any ideas on what could be causing the failures?
  2. Re: Indicators Blowing Fuses
    Jul 2008
    Oslo, Norway
    Sounds like a short circuit (probably bad wiring) some place. The usual suspects would be movable connections in the ignition switch, the stalk switch.
    I'd have the ignition switch checked first (especially if your headlights act funny and your windscreen wipers die on you) if the fuses blow while the engine is running (or ignition is on).
    If the fuses blow when the key is out, and you test your hazards, have your wiring checked.
  3. Re: Indicators Blowing Fuses
    Sep 2007
    blew the fuses whilst driving
    blew the fuse whilst stationary and engine shut down
    going to Auto Leccy later in the week
  4. Re: Indicators Blowing Fuses
    Sep 2007
    OK, it's been in today from 9 till 4 but unable to trace the fault. Hasn't blown a fuse for them in the garage, engine running and shut down, out on a test run.
    I thing I have noticed is that the indicator lights now don't flash when the car is locked/unlocked using the remote key fob. They were working before it started to blow fuses.
    Could the issues be connected or is the lock/unlock flashing on another fuse
  5. Re: Indicators Blowing Fuses
    Dec 2007
    Suffolk
    It could be a fault with the central convieniance unit/wiring under the passenger side front carpet, they are very prone to water damage.
  6. Re: Indicators Blowing Fuses
    Sep 2007
    Quote Originally Posted by smokey0123 View Post
    I'll have a look/feel but the windows show know sign of condensation
  7. Re: Indicators Blowing Fuses
    Sep 2007
    It's very dry
  8. Re: Indicators Blowing Fuses
    Jul 2008
    Oslo, Norway
    My Passat usually exhibited curious behaviour whenever the wiring went bad. The last time I had untracable gremlins when my rear doors wouldn't lock or open remotely, I found out it was worn wiring in the real left door between the door and the pilar/column.
    Then before that it was theindicators going on strike when the engine was running, and the climatronic displayig some Marsian symbols, turned out to be a bad ignition switch.
    I still put my money on bad wiring in your case, though.
    Were the doors open when they were checking it at the workshop and came out empty? Maybe there could be something there.
    Also try inspecting the wiring at all the obvious places you would expect wear from use or weather (like the connectors in the dome, badly seated or rated fuses, unfaithfull relays, moiusture in the indicator housing, etc).
    My 1 cent.
  9. Re: Indicators Blowing Fuses
    Bourne End , Bucks
    Hi, Do you have a tow bar and the electrics installed, I just had a similar problem, and found the tow bar relay had blown, this caused my indicator lights to play up and blow the fuse.
  10. Re: Indicators Blowing Fuses
    Sep 2007
    Quote Originally Posted by doug.howsie View Post
    No tow bar fitted to mine.
    Indicators work fine now, but, I'm still without indicators when I lock/unlock the car with the remote
  1. Audi 94 coupe Blowing fuses
    By naz121 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 08-06-2010, 06:56 PM
  2. Please Help Audi 90 CS Fuses #12 & # 14 keep blowing help!
    By armyvet207 in forum 80 - 90
    Last Post: 14-06-2008, 11:57 PM
  3. Mk3 Tdi fuses blowing
    By phil123 in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 10:13 PM
  4. blowing fuses
    By majick in forum TT - 8N Forum - 1998 - 2006
    Last Post: 08-06-2007, 12:24 PM
  5. BORA fuses blowing ? Which fuse how many Ampere ?
    By henri in forum Bora - 1998 - 2005
    Last Post: 22-02-2006, 11:23 PM
