Thread: Golf mk2 16v (1990)
Page 6 of 6 FirstFirst ... 456
Results 51 to 52 of 52
  1. Re: Golf mk2 16v (1990)
    #51
    Hi there, still have the same problem, not driven the car for a while now, as i have got pi**** of with it. Could fuel problems cause this problem my car is having.
  2. Re: Golf mk2 16v (1990)
    #52
    1836 Post(s)
    You say that the main fuel pump is whining. This can be due to a failed in tank lift pump which needs testing and if it is not working, it may have damaged the main pump so both will need changing. If the lift pump is working and the main pump noisy then the main pump will need changing which can be a trial when dealing with corroded fuel lines and pump retaining ring screws where the heads have completely rusted away.
  1. 1990 VW Golf Diesel Question
    By kenvb in forum Golf MK2 - 1984 - 1992
    Last Post: 21-03-2008, 01:53 PM
  2. mk2 golf gti 1990 (Mk1 Cabriolet)
    By deego in forum Golf MK1 - 1974 -1984
    Last Post: 02-10-2007, 04:32 PM
  3. 1990 Golf GTi cabrio misfiring
    By Dave Clark in forum Archive posts
    Last Post: 04-06-2007, 07:53 PM
  4. 1990 Mk 2 Golf 1.3 Gearbox probs
    By radcliffe in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-03-2007, 12:23 PM
  5. 1990 GOLF CLIPPER HELP!!
    By chally34uk in forum Archive posts
    Last Post: 05-12-2005, 08:54 AM
