Thread: Engine Oil recommendation
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. Engine Oil recommendation
    Boraboy Guest
    Can anyone tell me what the best engine oil is for my car? 1.9TDI diesel engine..... light came on today and the manual states:
    VW 506 01 - Oil for long life service
    VW 505 01 - Multi Grade high lubricity oils
    Bit confused....does anyone just use Castrol ?
    Mark
    PM oilman He could help.
    Regards Boardboy
  3. Question
    Nov 2006
    Swampyland, UK
    Quote Originally Posted by Boraboy View Post
    Oh dear - why oh why can't people use a ******** dipstick!!!!!
    the manual states:
    Righty, what type of service regime are you on? Either fixed interval (fixed miles and fixed date, upto 10k miles or 1 year), or LongLife variable service (upto 20k miles or 2 years)?
    Mark
    You must ONLY use an oil which is approved for your Pumpe Duse (PD or unit injector), otherwise SERIOUS engine damage will occur. Do not use Mobil 1, as these have never been tested by VW (dispite the claim on the bottle of Mobil 1 that it "meets" the VW standards).
    Take a look at the following thread https://www.vwaudiforum.co.uk/forum/s...ead.php?t=1482, have a detailed look at my reply - post #12 - be careful of the very generic statements from "oilman" - quite simply, as per your manual, you MUST buy an oil which has either VW 505.01, or 506.01 on the bottle, anything else is completely irrelevant!
    Rgds
    Nov 2006
    Swampyland, UK
    Quote Originally Posted by Boardboy View Post
    Regards Boardboy
    Yebut - his advice isn't always correct, and his prices are no cheaper than *********. And why PM, what's wrong with posting the info here on the forum, so everyone can see the answers.
    Rgds
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    If the light is on GET SOME OIL IN NOW! Doing damage to the engine if you run it too low. Chuck any old stuff in, in the short run. However, the best top up oil to carry around in a 1 litre pot is 505.01 stuff. It's designed for the 10k service interval, and 506 stuff is for longer service intervals. I use 505.01 and change my oil/filter every 7k, also carry a 1 litre pot in the boot as my turbo has a very slight oil leak from one of the feed pipes - so small it bearly affects the levels, but it tends to need a bit of a top-up halfway through between services.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
  6. Oil
    From the information that I have:
    505.01 is the same as 5W/40 for the standard service life
    On the longlife schedule: 0W/30
    I'm sure Castrol will have equivilent oils but if unsure then just go to your local VW dealer (or independant) and buy some from the service department.
    Regards
    Richard
    Nov 2006
    Swampyland, UK
    Quote Originally Posted by RichieVWV6 View Post
    I would approach VW dealers with a little caution. I have personaly repeatedly experienced problems with my own main *******, and other no-so-local main ********, trying to tell me to put the wrong oil into both my S4 and my GTI. One dealer even admitted to engine failures from using the wrong oil, and that VW refused the Warranty repair because of the wrong oil! Another area of concern is the actual contracted supply of oil to the dealer - some use Castrol, some use Shell, some use Fuchs, and some use Mobil. The first three are all OK, because they do actually have the specific VW approved oils in their respective ranges. Those dealers who use Mobil could seriously be in the $hit, because no Mobil oil has ever been submitted to VW (and therefore tested, and subsequently approved) for either Pumpe Duse unit injector turbo diesels, or any LongLife specifications!
    If the OP advises the forum which regime his car is on, then I can post a list of the relevant VW approved oils.
    Rgds
    Boraboy Guest
    Ive only had the car since September 2006, and they told me that the car had been fully serviced prior to me buying it....never had a deisel before so was under the (wrong) impression that you dont top up regularly.....
    The last service was done in May 2006 officially, (stamped) and no doubt the levels were checked again in Spetember when I bought it.
    I would assume that I have a choice of service intervals? or can someone recommend what service interval I should use as I mainly use the car for motorway driving and local school runs.
    Mark
    Boraboy Guest
    Just had a look at the service book.... it was last serviced on 15/5/06 with 50,223 miles on the clock. Ive had the car 4 months and have done 3500 miles thus far.
    The stamps have been put on the LongLife Service section......
    sorry to 'hijack' this thread and please dont ignore the initial question but im trying to clear up a bit of confusion.... you have reccomended the type of oil etc, so supposing you walk into *********, am i going to be able to get the diesel oil i need from there or am i going to have to visit a car spares supplier?
  1. Engine Fans Start Up after Engine is Switched off??
    By batman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2009, 02:15 PM
  2. engine drop - engine mountng bolts sheer
    By shazzander in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-04-2007, 03:29 PM
  3. Recommendation
    By andy_b in forum Chat - Completely Off Topic
    Last Post: 19-01-2007, 02:07 AM
