Thread: MK3 Golf GTI 8V timing 1997
Results 1 to 10 of 16
  1. MK3 Golf GTI 8V timing 1997
    Jun 2008
    I have a Mk3 golf 2.0L 8V GTI, when I read the fault codes, I am getting 00515 outside specifications. The car has been cutting out when I am driving it.
    I have had a new Destributor fitted and the cam sensor changed.
    Can anyone tell me how to check/change the timing and what/where I could be looking on VAG-COM.
  2. Re: MK3 Golf GTI 8V timing 1997
    131 Post(s)
    1973 Post(s)
    That will have an AGG code engine. The distributor hall sender is out of sync and so the distributor needs top be repositioned. Start the car and enter Engine 01, Measuring Blocks 007 and four blocks of data will appear. Rotate the distributor until the value in block 1 is between 57 and 60 or 1 and the value in block 2 is between 5 and 8.
  3. Re: MK3 Golf GTI 8V timing 1997
    Jun 2008
    Thanks for that, the problem is now sorted. Just to confirm for anyone has with the same issue, it's group 007 you need to look at.
    Thanks Again.
  4. Re: MK3 Golf GTI 8V timing 1997
    131 Post(s)
    1973 Post(s)
    Your quite right, stupid keyboard manufacturer put 7 next to 8 on the keyboard
  5. Re: MK3 Golf GTI 8V timing 1997
    Hi. im new to this.
    Ive seen that you have the same sort of problem as me, but my car has stopped running all together now. I know that when it was running i had plugged it on to a snap on scanner and it showed the hall effect sensor...
    But now my has stopped running. turns over, got fuel but no spark...
    can anyone help??
    Any help would be great
    Ashley Coombs
  6. Re: MK3 Golf GTI 8V timing 1997
    131 Post(s)
    1973 Post(s)
    The most likely reason is the coil. The ECU will trigger the coil even if the distributor hall sender is unplugged, an ADY or AGG will run almost as well as normal up to 5K rpm with the hall sender unplugged, all it does is to tell the ECU where number one piston is so as it may initiate sequential rather than full group injection.
  7. Re: MK3 Golf GTI 8V timing 1997
    Hi.
    Thanks for the information. I'll have to try it. I was thinking it could be the crank sensor.
    Thanks again
    Ashley Coombs
  8. Re: MK3 Golf GTI 8V timing 1997
    131 Post(s)
    1973 Post(s)
    Possibly but that usually gives a fault code, but not always. The engine speed sender G28 (on the front of the engine block) is not what VW refer to as the hall sender G40, which is inside the distributor.
  9. Re: MK3 Golf GTI 8V timing 1997
    Dec 2007
    Suffolk
    If its injecting fuel then crank sensor is working
  10. Re: MK3 Golf GTI 8V timing 1997
    hello. me again. i've managed to plug my car on to a VAG comp. when i'm looking at the measurements the values always change. even if i adjust the dissie. could this be down to the cam belt timing or another sensor?? please help its bugging me....
  1. Audi a4 tdi 1997 timing marks
    By shuvit2 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-04-2008, 10:55 PM
  2. Golf 1.9D 1997 Mk3
    By a1taff in forum Golf MK3 - 1993 - 1999
    Last Post: 13-02-2008, 12:16 PM
  3. 1997 VW Golf Mk3 TDI
    By slysi in forum Golf MK3 - 1993 - 1999
    Last Post: 12-02-2008, 05:35 PM
  4. Golf 1997 GL
    By x2epsilon in forum Golf MK3 - 1993 - 1999
    Last Post: 30-01-2008, 11:51 AM
  5. 1997 Golf 1.6 - Oil in Air Box
    By bigcrags in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-09-2007, 02:15 PM
