Thread: DTCs not supported
  1. DTCs not supported
    Bulgaria
    Hi evebody,
    Greeting from Bulgaria.
    First to say you got a very nice VAG dedicated board.
    And now my problem:
    After connecting two different cheap ebay cables to my 1998, 1.6, AEH, golf 4, I am able to read all available in my car modules except the Engine in the first tab which I need to read. The error I get is this:
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 06A 906 019
    Component and/or Version: 1.6l R4/2V SIMOS 22272
    Software Coding: 0004030
    Work Shop Code: WSC 01317
    No Faults Found
    or DTCs not supported by controller
    a communication error ocurred
    It seems strange to me to be able to read other modules like ABS, auto transmission and not able to read this one.
    Is this a cable problem or a software problem?
    Any help is appreciated.
  2. Re: DTCs not supported
    Lansdale, PA, USA
    Try these suggestions.
    If none of that works, try a real interface instead of a fleaBay special..;-)
    -Uwe-
    www.Ross-Tech.com
    Satisfaction guaranteed or double your fault codes back!
  3. Re: DTCs not supported
    Bulgaria
    Thanks a lot Uwe!
    I'll try all of the above, hope it will work.
  1. Interpret these DTCs plz
    By Loofer in forum VCDS - General Questions
    Last Post: 01-09-2007, 07:21 PM
