Thread: Heated Washer Jets for Windscreen
Results 1 to 8 of 8
  1. Post Heated Washer Jets for Windscreen
    North West
    I have a 2004 Polo Twist 1.4 16v which came with heated / electric mirrors, but not heated windscreen washer jets, only available on a 'Winter Pack' I think. Is there any way to retrofit heated washer jets on the polo. I understand the car has a distributed CAN BUS system, would it be necessary to have the car configured to use the extra electrical components, as this would seem to be the case with most CAN systems? Any clues would be appreciated. If there's nothing out there at a resonable cost I might consider creating my own retrofit kit.
  2. Re: Heated Washer Jets for Windscreen
    131 Post(s)
    1973 Post(s)
    They are always on with the ignition and directly powered from fuse 19 and not connected to the on board power supply unit so rigging them up should be easy. All the parts are easily available. The jets are available from VW under the part number 6E0 955 986 B and cost £14.23 each and the harness is available form VW under the part number 6Q0 971 204 D for £32.87 although this harness changed during 2003 but as your car is a 2004 you should be OK. The connections should be in the engine bay if I remember correctly and you just need to put a fuse in position 19.
  3. Re: Heated Washer Jets for Windscreen
    North West
    Thanks for the detailed reply, exactly what I was after. I'll obtain items and post how I get on.
  4. Re: Heated Washer Jets for Windscreen
    Dec 2007
    sorry to butt in just wanted to say i have the same car!
  5. Re: Heated Washer Jets for Windscreen
    North West
    It's taken about 3 weeks for the parts to arrive, had to wait for the wiring harness. Fitted the Harness/water feed item in about 60 mins, taking care when removing the under-bonnet cover to gain the necessary access. Feeding the harness was a little testing at times. Only when I've had the parts ready to fit have I moved the plastic gutter below the windscreen, and found a problem. Where's the electrical connector to power the harness? it can only be within 10cm of the water pipe connection on the near side, but I can't see it. I've left it all installed whilst I locate the outlet plug to connect to the harness socket. Any idea's?? I know I could rig up a supply to do the job, but would like to wire the harness as VW planned it.
  6. Re: Heated Washer Jets for Windscreen
    131 Post(s)
    1973 Post(s)
    That isn't a harness as such but a single wire. If you want to make it up properly, I can email the diagram which is very simple and you will need VW contact housing 1J0 973 702 or 1J0 973 802 (basically the one of these the harness you have doesn’t have on it already) and the pins to go inside it which are not available from VW but I do keep them. Then you would need some 1.0-mm red and 1.0-mm brown wire. The red runs inside the car to a red six pin connector block under the dash that takes power from fuse 19 (ignition live) and the brown wire runs to an earth point in the engine bay.
  7. Re: Heated Washer Jets for Windscreen
    Crasher,
    I've just bought the equivalent harness/jets from Seat to retrofit on my MY2006 Seat Leon. Could you help me with an absolute Idiots guide as to what I need to do further to connect this up the fuse box?
    Vw Golf GT 1.4 Tsi (170) 07 Plate in Black (soon to be lost )
    Seat Leon TFSi Sport (185) 06 Plate in Black
    Seat Altea XL 1.8 TSi (160) 08 Plate in Black (awaiting delivery)
  8. Re: Heated Washer Jets for Windscreen
    131 Post(s)
    1973 Post(s)
    I can't do you an idiot’s guide as I have never done it myself, it is all theory. The hardest part would be running the power wire into the car and finding the correct output using the wiring diagram.
  1. Heated washer jets - Seasonal Topic!
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-12-2007, 05:35 PM
  2. Heated washer jets not working.
    By BenR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-12-2007, 11:18 AM
  3. windscreen washer fluid low warning
    By sbt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-10-2007, 03:37 PM
  4. B6 Windscreen spray jets on mk4 golf?
    By mobitune in forum Chat - Anything with wheels
    Last Post: 20-10-2007, 11:39 PM
  5. Heated windscreen washer jets?
    By Zub in forum Passat - Archive Topics
    Last Post: 02-03-2007, 04:55 PM
