Thread: A how-to with some VAG-COM modules
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
  1. A how-to with some VAG-COM modules
    Mar 2007
    Lancashire
    Since getting a genuine Ross-tech cable I've been able to make a few changes to my car that work successfuly. With all the info on the web I thought I would note them down here for anyone who wants to make quick changes without trolling the web.
    If some are obvious then apologies. It has simply allowed me to make the car more functional to how I would like it.
    Ross-tech HEX-COM cable serial interface on a 2001 A4 1.9TDI
    First change I made was to the service intervals. I wanted 6 months or 5,000 miles as I like to drain the oil that frequently on the TDi. Note the values in bold I have changed and are personal preference.
    After launching VAG-COM select the following:-
    17-Instruments - Adaption-10 - Ch No. 42 Oil in 1 - min value 5
    43 Oil in 1 - Max vaule 5
    44 Insp 1 - Max days 182 (6 months)
    There is plenty of talk re MPG and mine was very optimisitc. I calculated the true MPG and took a percentage difference. It was about 10% optimistic! Why have a DIS that shows incorrent miles left and average consumption. I've changed this:-
    17 - Instruments - Adaption-10 - Ch No. 3 - Origininal val 100 (this is a %) my new value is 110. Use TEST and see Average MPG drop in DIS!
    I also wanted central locking at speed. This requires some calculation in Binary mode, but very easy.
    46 - Central Conv - Coding-07 - Original Val 6859 New Val 6891
    The following codes were active on my car. I simply added 32 to the orginal value and the doors now auto lock. Equally, by removing a Binary for the total value you would disable that function.
    BinaryFunction 1GB Alarm
    2 Anti theft warning bleep
    8 Anti theft warning system
    32 Auto Central Locking at 15 mph
    64 Comfort function via remote control
    128 Right hand drive
    512 Confirmation close via remote
    2048 Door/Window regulator logic
    4096 Thatchem anti-theft warning
    Hope this may help some of you. As I said, it is documented throughout the internet but we may as well build up a database of common changes that are easy to locate.
    Regards
    Mark
  2. Re: A how-to with some VAG-COM modules
    Canada
    Thanks for the write up, car lock at 15mph like a dream now, unlocks when i remove the key from the ignition
  3. Re: A how-to with some VAG-COM modules
    May 2007
    Liverpool
    Do you know how to make the lights come on when the car is unlocked? I've heard this only works on Audi's tho but i'm not sure.
  4. Re: A how-to with some VAG-COM modules
    Mar 2007
    Lancashire
    Glad you've sorted the autolock.. I like it when it un-locks when the key is removed..
    I'm not sure how to set the lights to come on... will investigate that one.
    Onzarob - what changes have you made to the egr??? Interesting to know if you don't mind??
  5. Re: A how-to with some VAG-COM modules
    Canada
    I've just set the EGR to the lowest level, mainly due to it not affecting to much,as a test, but have found a difference, the car smokes less
    Go into ECU with engine running and login code 12233. then click adaption and channel 03 should have a value of 32768, change the value to 33768 and jobs done, it may give a slighty lower value but thats ok.. This info is on the ross-tech site. have a go
  6. Re: A how-to with some VAG-COM modules
    Bristol
    Quote Originally Posted by onzarob View Post
    Just done this too , works a treat so far ,
    MK5 Golf TDI 2.0ltr GT Sport in Black
  7. Re: A how-to with some VAG-COM modules
    Bristol
    Engine idle speed adjustment ,
    I did this last night stock idle is meant to be 903 rpm , mine was at 810rpm, i got it upto to 861 rpm, as the max figure i can input was 32800 from 32768 .
    [Select]
    [01 - Engine]
    [Login - 11]
    [Adaptation - 10]
    Enter the "channel number" below to select each channel.
    Put in the suggested value(s) in "new value".
    [Test]
    Observe the "test value" field to make sure the adaptation setting is acceptable.
    [Save]
    Channel 2: idle speed
    • No login required
    • The stock adaptation value should be 32768 (corresponds to 903 rpm).
    • Increase or decrease this to change idle speed.
  8. Re: A how-to with some VAG-COM modules
    East Yorkshire
    Quote Originally Posted by Marco34 View Post
    I tried this on my Passat se 130 tdi today but when I got to coding 07 I couldnt find the value of 6859 to change and couldnt find this binary mode you talk about where is that.
    Anyone tell me what I am doing wrong.
    Regards Steve
  9. Re: A how-to with some VAG-COM modules
    Is it possible to find how how many MPG you do using Vag Com?
  10. Re: A how-to with some VAG-COM modules
    krobb45 Guest
    I tried to enable the central locking speed on my '99 A4 B5, but Vag-Com won't read the 46-Central Conv. module. Any suggertions?
  1. Diesel Power Modules
    By ½cwt in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-03-2007, 05:55 PM
  2. Diesel Tuning Modules
    By hedropsforglory in forum Chat - Completely Off Topic
    Last Post: 26-01-2007, 09:20 PM
