Thread: G247 Fuel Pressure Sensor Help
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
  1. G247 Fuel Pressure Sensor Help
    Oct 2010
    Here And There
    Hi there folks. I noticed that my 2.0 TFSI A4 has devoloped a 'stutter' or loss of power whn I am putting it under load in third, fourth, fifth or sixth gear, more noticable in third and forth when pulling out of a slip way onto a motor way etc.
    I carried out a code read this evening and found the below fault :
    Readiness: 0000 0100
    Saturday,05,May,2012,19:38:10:19796
    VCDS Version: Release 11.11.1 (x64)
    Data version: 20111209
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Control Module Part Number: 8E0 910 115 Q HW: 8E0 907 115 D
    Component and/or Version: 2.0l R4/4V TFSI 0030
    Software Coding: 01040003180F0120
    Work Shop Code: WSC 66565 257 00032
    VCID: 2F6618D4BE066C1
    004506 - Fuel Pressure Sensor (G247)
    P119A - 001 - Malfunction
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 6
    Mileage: 192316 km
    Time Indication: 0
    Freeze Frame:
    RPM: 763 /min
    Load: 13.3 %
    Speed: 0.0 km/h
    Temperature: 69.0°C
    Temperature: 25.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 14.224 V
    I have only spent a little time this evening on it and have erased the faults to see what reappears after driving it tomorrow again but I have never came across this fault before and have done a little Saturday night 'Googling' while me and the wife watched a crap movie and have found mixed opions from folk saying that its either a sensor on the fuel rail or the hpfp itself. My understanding from what I seen with the little time that I had spent on it tonight is that the fuel pump sensor that sits on top of the hpfp is working as I used VCDS to activate it and it clicked on and off and did not bring up any faults after activation.
    Has anyone had any experiance with this fault ?
  2. Re: G247 Fuel Pressure Sensor Help
    131 Post(s)
    1974 Post(s)
    Replace the lift pump in the tank first, this is the cause most of the time.
    Oct 2010
    Here And There
    Thanks Crasher for the reply. In the tank itself ? I take it that is the sensor simply picking up on actual low pressure then ? Have you seen this before Crasher ? It had me thinking it was the sensor as it said 'malfunction' rather than 'out of spec' or 'too low' ?
  4. Re: G247 Fuel Pressure Sensor Help
    May 2007
    knee deep in clunge
    14 Post(s)
    I have all kinds of fun with this engine and the main four parts i replace for fuel pressure are
    fuel filter (pressure valve built in)
    fuel pressure limiting valve (I will send you a pm of its location)
    pressure pump (in tank)
    low pressure sensor (if it has the part number 06e 906 051k its the latest modified sensor)
    The problem is if you use mvbs to check the rail pressure it rarely shows you its out as its tested at idle so if you can connect a inline pressure gauge and road test it
    I found the pressure before the filter and after the filter is a critical test and you can check the delivery rate as well to make life easier on road test connect a amp clamp to the pump and you will see if the pump amperage spike's or not as well as how hard its working
    So if its working its balls off and you have a low pressure reading then the supply is restricted (filter blocked) or weak pump
    There is also a pump control unit to take into account but DONT GET ALL CONFUSED A PRESSURE TEST IS FAR MORE INFORMATIVE THAN ANY MVB VCDS READING
    I have spent a lot of time dealing with fuel pressure problems and these are my findings, the main problems are blockage/restrictions for fuel on demand requirements
    the limiting valve is a mechanical valve which blocks up (see your pm)
    One other overlooked problem around 5000 rpm is the plugs
    Also the injectors carbon up and create sporadic misfires, these misfires are compensated for and only possible to test with a scope
    Misfire detection kicks in and suppressor the cylinder in question turning the spark off and balancing the other cylinders to smooth out the running
    Reet off fishing no private work today lol
  5. Re: G247 Fuel Pressure Sensor Help
    Oct 2010
    Here And There
    Thanks A8 for the reply. I know it means nothing in this game these days but I replaced the spark plugs and the fuel filter with genuine Audi parts last year and have only done 3'000 miles ( she is only for the weekends lol ) and I have also had the coil packs replaced under the recall at the time so hopefully they are ruled out.
    I assume that when you mean to test the pressure before and after the filter, you mean with some sort of gauge connected at the two said points ? I dont have a pressure gauge for fuel that would have the connectors that I would need as I have never needed it
    To both Crasher and A8 ( after eating his Rainbow Trout ) : I know this is very novice of me to say but do you think that that I should buy the G247 sensor ( http://www.ebay.co.uk/itm/NEW-GENUIN...item5d2f46c478 ) and throw on a new limiting valve as its only £5 at the same time ( http://www.ebay.co.uk/itm/New-Genuin...item20abc717dc ) and try them first ?
    I know its more 'try and error' rather than a proper diagnostic approach but I dont have the gauges to test the pressure properly and by the time I buy them, it will cost me more money.
    Oct 2010
    Here And There
    O
  7. Re: G247 Fuel Pressure Sensor Help
    May 2007
    knee deep in clunge
    14 Post(s)
    The part numbers are in the link sent via pm fool.
    You ok mate, take g247 off and check the part number to see if its the latest one
    As for the fuel pressure and the new filter I have seen a few new filters fail as this filter also fits r8 I have replaced one 1 year after it was replaced for fuel contamination
    Problem, poor warm starting int misfire
    The pressure limiting valve is a pig to change (manifold off job) but its something I change now as a precaution and when to look inside you find its full of gunk
    Might be coming off the spanners soon (not at the weekend though lol) workshop manager
    As young crasher has said the pressure pumps can play up but take the pump out and remove the sieve, look for metallic bits showing signs of internal wear
    measured values
    Unified measured value blocks - petrol engines
    2.0L T-FSI version 1.24
    Breakdown of measured value blocks
    001 - 009 ....... General representation of system status
    010 - 019 ....... Ignition
    020 - 029 ....... Knock control
    030 - 049 ....... Lambda control / catalytic converter
    050 - 059 ....... Speed control
    060 - 069 ....... Throttle control
    070 - 079 ....... Emissions reduction
    080 - 089 ....... Special functions / Ready bits
    090 - 097 ....... Power increase
    098 - 100 ....... Compatibility blocks
    101 - 109 ....... Fuel injection
    110 - 119 ....... Load recording
    120 - 129 ....... Communication between control units
    130 - 139 ....... Cooling
    170 ....... Starter control
    Measured value block 001:
    General
    1)Engine speed [rpm]
    2)Coolant temp. [°C]
    3)Lambda control value bank 1[%]
    4)Setting conditions for basic setting
    1 2 3 4 5 6 7 8
    X Coolant temp.>80°C -
    X Engine speed<2000 rpm
    X Throttle valve closed
    X Lambda control OK
    X Idling speed switch closed
    X AC compressor off
    X Cat. temp. reached
    X No fault in system
    (Condition met = 1; condition not met = 0)
    Measured value block 002:
    General (systems with one air mass meter)
    2)Load [%]
    3)Mean injection time [ms]
    4)Air mass [g/s]
    Measured value block 003:
    2)Air mass [g/s]
    3)Throttle angle (potentiometer) [%]
    4)Ignition timing angle (actual) [° b.TDC ]
    Measured value block 004:
    General
    2)Voltage [V]
    3)Coolant temp. [°C]
    4)Intake air temp. [°C]
    Measured value block 005:
    General
    2) Load [%]
    3)Road speed [km/h]
    4)Operating status (LL, TL, VL, S, BA)
    LL: Idling speed
    TL: Part throttle
    VL: Full throttle
    S : Overrun
    BA: Acceleration enrichment
    Measured value block 006:
    General
    2)Load [%]
    3)Intake air temp. [°C]
    4)Altitude correction [%]
    (Ratio to reference level; 0% = 0m; -50% = 5,000m; +20% = -2000m)
    Measured value block 007:
    General
    2) Load [%]
    4)BDE mode
    1 2 3 4 5 6 7 8
    X Homogeneous
    X Homogeneous lean
    X Homogeneous stratified
    X Stratified
    X Stratified cat.heating
    X Vacant
    X Vacant
    X Homogeneous knocking protection
    If stratified prohibited, via 2 ASCII characters SV
    Measured value block 008:
    Vacant
    Measured value block 009:
    ESI (extended service intervals)
    1)Oil level [mm]
    2)Oil warning threshold [mm]
    3)Fuel consumption signal [litres]
    4)Consumption equivalent
    Measured value block 010:
    Ignition
    2)Load [%]
    Measured value block 011:
    Ignition
    Measured value block 012:
    Distributor setting
    Vacant
    Measured value block 013:
    Vacant
    Measured value block 014:
    Misfire detection
    2)Load [%]
    3)Misfire totaliser [n]
    4)Misfire detection [activated/disabled]
    Measured value block 015:
    Misfire detection
    1)Counter cyl. 1 [n]
    2)Counter cyl. 2 [n]
    3)Counter cyl. 3 [n]
    Measured value block 016:
    Misfire detection
    1)Counter cyl. 4 [n]
    2)Counter cyl. 5 [n]
    3)Counter cyl. 6 [n]
    Measured value block 017:
    Misfire detection
    Vacant
    Measured value block 018:
    Load/speed window, misfire detection
    (If no misfires detected: 0 at all positions)
    1)Lower engine speed threshold [rpm]
    2)Upper engine speed threshold [rpm]
    3)Lower load threshold [%]
    4)Upper load threshold [%]
    Measured value block 019:
    Vacant
    Measured value block 020:
    Knock control
    1)Ignition retard cyl. 1 [°CA]
    2)Ignition retard cyl. 2 [°CA]
    3)Ignition retard cyl. 3 [°CA]
    4)Ignition retard cyl. 4 [°CA]
    Measured value block 021:
    Knock control
    Vacant
    Measured value block 022:
    Knock control
    2) Load [%]
    3)Ignition retard cyl. 1 [°CA]
    4)Ignition retard cyl. 2 [°CA]
    Measured value block 023:
    Knock control
    2) Load [%]
    Measured value block 024:
    Knock control
    Vacant
    Measured value block 025:
    Knock control
    Vacant
    Measured value block 026:
    Knock sensor voltages
    1)Cyl. 1 [V]
    2)Cyl. 2 [V]
    3)Cyl. 3 [V]
    4)Cyl. 4 [V]
    Measured value block 027:
    Vacant
    Measured value block 028: Basic setting
    Test knock sensors
    - Function 04 (Basic setting)
    - Activate short trip
    - Press brake pedal and at same time press accelerator pedal down fully:
    - Engine speed automatically adjusts to 2200 rpm -> "Test ON"
    - Wait for "Syst. OK" to be reached in the 4th field
    2) Load [%]
    4)Result [Test ON/Test OFF/Sys. OK/Sys. n.OK]
    Measured value block 029:
    Reserved fir knock control adaption
    Vacant
    Measured value block 030: 1-bank systems
    Lambda probes, status
    1)Bank 1, probe 1
    (Meaning of 5-digit number block)
    4 3 2 1 0
    X Control active
    X Probe ready
    X Probe heating on
    X Cat.clearing active
    X Vacant
    1: Condition met
    0: Condition not met
    2)Bank 1, probe 2
    (Meaning of 4-digit number block)
    3 2 1 0
    X Control active (I-component)
    X Probe ready
    X Probe heating on
    X Control active (P-component)
    1: Condition met
    3)Bank 1, probe 3
    Vacant
    4)Vacant
    Measured value block 031: 1-bank systems
    Continuous lambda probes
    1)Lambda actual bank 1 []
    2)Lambda specification bank 1 []
    3)Not used
    4)Not used
    Measured value block 032: 1-bank systems
    Lambda probe learned values (max. value)
    1)Bank 1, probe 1, idle [%]
    2)Bank 1, probe 1, part throttle [%]
    3)Not used
    4)Not used
    Measured value block 033: 1-bank systems
    1)Bank 1, control value [%]
    2)Bank 1, lambda probe voltage [V]
    3)Not used
    4)Not used
    Measured value block 034: Basic setting
    Lambda probe ageing check bank 1 or 3 before cat - continuous probes
    - Engine speed automatically adjusts to 1800 rpm -> "Test ON"
    - Wait for "B1-S1 OK" to be reached in the 4th field
    2)Exhaust/cat.temperature bank 1 or 3 [°C]
    3)Dynamic value bank 1 or 3 [ ]
    4)Result [Test ON / Test OFF / B1-S1 OK / B1-S1 n.OK]
    Measured value block 035: 2-bank systems Basic setting
    Vacant
    Measured value block 036: 1-bank systems Basic setting
    Lambda probe readiness after cat.
    - Wait for "B1-S2 OK" to appear in the 2nd field and "B2-S2 OK" in the 4th.
    1)Probe voltage bank 1, probe 2 [V]
    2)Result [Test ON/Test OFF/B1-S2 OK/B1-S2 n.OK]
    3)Probe voltage bank 1, probe 3 [V]
    4)Result [Test ON/Test OFF/B1-S3 OK/B1-S3 n.OK]
    Measured value block 037: Basic setting
    Lambda probes bank 1, delta-lambda - continuous probes
    - Wait for "B1-S1 OK" to appear in the 4th field.
    1) Load [%]
    2)Bank 1, probe 2: Lambda probe voltage after cat. [V]
    3)Bank 1: Duty cycle shift [ms]
    4)Result [Test ON / Test OFF / B1-S1. OK / B1-S1. nOK]
    Measured value block 038: 2-bank systems Basic setting
    Vacant
    Measured value block 039: 2-bank systems Basic setting
    Vacant
    Measured value block 040: 2-bank systems
    Vacant
    Measured value block 041: 1/2-bank systems
    Lambda probe heater, bank 1
    1)Internal resistance bank 1, probe 1 []
    2)Status/duty cycle bank 1, probe 1 [Htg.bC.ON/Htg.bC.OFF/%]
    3)Internal resistance bank 1, probe 2 []
    4)Status bank 1, probe 2 [Htg.aC.ON/Htg.aC.OFF]
    Measured value block 042: 1-bank systems
    Vacant
    Measured value block 043: Basic setting
    Lambda probe ageing after cat., bank 1
    - Wait for "B1-S2 OK" to appear in the 4th field.
    2)Exhaust/cat.temperature bank 1 [°C]
    3)Lambda probe voltage bank 1, probe 2 [V]
    4)Result [Test ON / Test OFF / B1-S2 OK / B1-S2 n.OK]
    or [Test ON / Test OFF / B3-S2 OK / B3-S2 n.OK]
    Measured value block 044: Basic setting
    Vacant
    Measured value block 045:
    Vacant
    Measured value block 046: Basic setting
    Cat. conversion test, bank 1 / bank 3
    - Short trips in blocks 034 / 035 / 036 / 037 / 038 / 039 / 043 / 044
    must be completed "OK"
    - Wait for "CatB1 OK" to appear in the 4th field.
    2)Cat.temperature bank 1 [°C]
    3)Readout cat. conversion bank 1
    4)Result [Test ON / Test OFF / CatB1 OK / CatB1 n.OK]
    or [Test ON / Test OFF / CatB3 OK / CatB3 n.OK]
    Measured value block 047: Basic setting
    Vacant
    Measured value block 048: Basic setting
    Vacant
    Measured value block 049: Basic setting
    Vacant
    Measured value block 050: Systems without rear window/air conditioner readiness isolation
    Engine speed increase
    1)Actual engine speed [rpm]
    2)Specified engine speed [rpm]
    3)Rear window heating/AC request [on/off]
    4)AC compressor [on/off/lower]
    Measured value block 050: Systems with rear window/air conditioner readiness isolation
    3)AC request [on/off]
    Measured value block 051:
    Engine speed, gear shifts
    3)Gear (automatic only) [0-7]
    P,N = 0
    Gear = 1 - 6
    R = 7
    4)Battery voltage [V]
    Measured value block 052: Systems with rear window/air conditioner readiness isolation
    3)Air conditioner readiness [off/on]
    4)Rear window/front windscreen heating [on/off]
    Measured value block 053:
    Engine speed increase based on alternator load
    3)Battery voltage [V]
    4) Alternator load [% or NM / W]
    Measured value block 054:
    Idling speed positioner/switch in electronic throttle systems
    2)Operating status [LL, TL, VL, SA, BA]
    Neutral
    LL: Idling speed
    TL: Part throttle
    VL: Full throttle
    S : Overrun
    3)Accelerator position sender 1 (potentiometer) [%]
    4)Throttle actuator angle (potentiometer) [%]
    Measured value block 055: Systems without rear window/air conditioner readiness isolation
    Idling speed stabilisation
    2)Idling speed controller []
    3)Current learned value, idling speed stabilisation [%]
    4)Operating states
    (Meaning of 6-digit readout)
    1 2 3 4 5 6
    X AC compressor On
    X Gear engaged
    X AC readiness/rear window heater On
    0 Always 0
    X Steering at full lock
    X Windscreen heater
    Measured value block 055: Systems with rear window/air conditioner readiness isolation
    4)Operating states
    1 2 3 4 5 6
    X AC compressor On
    X Gear engaged
    X AC readiness On
    X Rear window heater On
    X Windscreen heater
    Measured value block 056: Systems without rear window/air conditioner readiness isolation
    3)Idling speed controller []
    4)Operating states
    1 2 3 4 5 6
    X AC compressor On
    X Gear engaged
    0 Always 0
    X Windscreen heater
    Measured value block 056: Systems with rear window/air conditioner readiness isolation
    3)Air mass, idling speed controller []
    4)Operating states
    1 2 3 4 5 6
    X AC compressor On
    X Gear engaged
    X AC readiness On
    X Windscreen heater
    Measured value block 057:
    Idling speed stabilisation, pressure signal AC compressor / torque signal
    3)AC compressor [on/off/lower]
    4)Pressure pickup duty cycle/Pressure from air conditioner [%/bar]
    Measured value block 058: Systems with engine mounting only
    Vacant
    Measured value block 059
    Vacant
    Measured value block 060: Vehicles with electronic throttle Basic setting
    Electronic throttle adaption
    - Wait for "ADP OK" to appear in the 4th field
    1)Throttle angle (potentiometer 1) [%]
    2)Throttle angle (potentiometer 2) [%]
    3)Throttle valve adaption status [n]
    4)Operating status [Text: ADP runs/ADP OK/ERROR]
    Measured value block 061: Systems without rear window/air conditioner readiness isolation
    ESB/electronic throttle
    2)Battery voltage [V]
    3)Throttle valve angle [%]
    4) Operational status
    (Meaning of 4-digit readout)
    1 2 3 4
    X AC compressor On
    X Gear engaged
    0 Always 0
    Measured value block 061: Systems with rear window/air conditioner readiness isolation
    1 2 3 4
    X AC compressor On
    X Gear engaged
    X AC readiness On
    Measured value block 062:
    Electronic throttle, potentiometer voltages ratio U/Uref
    1)Throttle valve angle (potentiometer 1) [%]
    2)Throttle valve angle (potentiometer 2) [%]
    3)Pedal sender angle (potentiometer 1) [%]
    4)Pedal sender angle (potentiometer 2) [%]
    Measured value block 063: Basic setting
    Kickdown adaption (only in vehicles with automatic gearbox)
    - Function 04 (basic setting)
    - Press accelerator pedal fully down following prompt
    - Wait for "ADP OK" to be reached in the 4th field
    1)Pedal sender angle (potentiometer 1) [%]
    2)Learned kickdown point (potentiometer 1) [V]
    3)Kickdown
    4)Result (Press / ADP.runs / ADP.OK / ERROR)
    Measured value block 064:
    Throttle valve potentiometer adaption values
    1)Potentiometer 1 lower adaption [V]
    2)Potentiometer 2 lower adaption [V]
    3)Emergency air gap potentiometer 1 [V]
    4)Emergency air gap potentiometer 2 [V]
    Measured value block 065:
    Electronic throttle original adaption only for P/N system with EGR
    1)Throttle valve angle potentiometer 1 [%]
    2)Throttle valve angle potentiometer 2 [%]
    3)DVE adaption status [n]
    Measured value block 066: for 4-position operating lever
    CCS enabled
    1)Road speed actual [km/h]
    2)Switch settings
    (Meaning of 8-digit readout)
    1 2 3 4 5 6 7 8
    X Brake light switch Pedal pressed
    X Brake pedal switch Pedal pressed
    X Clutch switch Pedal pressed
    X CCS function enabled
    X ACC-CU fitted (ADR)
    X Main switch clocked
    X CCS status for CAN
    3)Specified road speed [km/h]
    4)Switch settings for 4-position operating lever
    1 2 3 4
    X CCS on/off
    X Set (CCS on)
    X Reduce
    X Increase
    Measured value block 066: for 4-position operating lever with CAN
    CCS enabled
    2)Switch settings
    1 2 3 4 5 6 7 8
    1 2 3 4 5 6 7 8
    X CCS on/off (CAN)
    X Set (CCS on)
    X Reduce
    X Increase
    X Vacant
    X Vacant
    X Vacant
    X CCS on (hardware pin)
    Measured value block 066: for 6-position operating lever
    CCS enabled
    2)Switch settings
    1 2 3 4 5 6 7 8
    4)Switch settings for 6-position operating lever
    1 2 3 4 5 6 7 8
    X CCS on/off
    X Set (CCS on)
    X Reduce
    X Increase
    X Set
    X Resume
    X Vacant
    Measured value block 067:
    Vacant
    Measured value block 068:
    Gearbox status
    2) Load [%]
    3)Gear [0-7]
    P,N = 0
    Gear = 1 - 6
    R = 7
    4)Converter/clutch status [text: TCC open / TTC close / TCC control]
    Measured value block 069:
    Vacant
    Measured value block 070: Basic setting
    Tank breather valve check
    - Idle
    - Wait for "TBV OK" to appear in the 4th field.
    1)Opening angle TBV [%] (duty cycle)
    2)Lambda controller/diagnosis value with active diagnosis [%]
    3)Idling speed controller/diagnosis value with active diagnosis [%/g/sec/ ]
    4)Result [Test ON / Test OFF / TBV OK / TBV n.OK]
    Measured value block 071: Basic setting
    Tank leak test (LDP, only with LEV)
    - Idle
    - Wait for "Syst. OK" to appear in the 4th field.
    1)Status of reed contact [text: Reed open / Reed closed]
    2)Fault message [text: Small leak / Large leak / Abort]
    3)Test status [- / Syst.test / Measurement / Meas.END]
    4)Result [Test ON / Test OFF / Syst. OK / Syst. n.OK]
    Measured value block 072: Basic setting
    Activated charcoal shut-off valve
    - Idle
    Measured value block 073:
    Vacant
    Measured value block 074:
    Vacant
    Measured value block 075: with temperature sensor Basic setting
    Vacant
    Measured value block 076: for pressure systems
    Vacant
    Measured value block 077: Basic setting
    Vacant
    Measured value block 078
    Vacant
    Measured value block 079Systems with exhaust gas flaps)
    Exhaust flap valves
    2)Load [%]
    3)Flap bank 1 [on/off]
    4)Flap bank 2 [on/off]
    Measured value block 080:
    CU identification
    1) Manufacturer works number and identifier
    2) Date of manufacture
    3) Manufacturer modification status
    4) Manufacturer test status number
    Manufacturer serial number
    Measured value block 081:
    CU identification
    1) Chassis number
    2) Module no./serial number
    3) Type test number
    4)
    Measured value block 082:
    CU identification
    1)Flash tool code
    2)Flash date
    3)HW module/type
    4)SW module/type
    Measured value block 083:
    CU identification
    1)Original chassis number
    2)
    3)
    4)
    Measured value block 084
    Vacant
    Measured value block 085:
    Vacant
    Measured value block 086:
    Ready and cycle bits
    1)Ready bits (completed tests)
    1= not completed
    0= completed
    1 2 3 4 5 6 7 8
    X Catalytic converter
    X Heat.cat.
    X ACF system
    X SA system
    X Air conditioner
    X Lambda probes
    X Lambda probe heating
    X EGR
    Specification:00000000
    2)Cycle flags (completed cycles)
    1= not completed
    0= completed
    1 2 3 4 5 6 7 8
    X Cat. bank 1
    X Cat. bank 2
    X LDP
    X TBV
    X Htg. B1-S1
    X Htg. B1-S2
    X Htg. B2-S1
    X Htg. B2-S2
    3)Cycle flags (completed cycles)
    1= not completed
    0= completed
    1 2 3 4 5 6 7 8
    X B1-S1 el.
    X B1-S2 el.
    X B1-S1 (delta-lambda shift)
    X B1-S2 (probe ageing)
    X B1-S1 (period)
    X SLS B1
    X SLS B2
    X B1-S1
    4)Cycle flags (completed cycles)
    1= not completed
    0= completed
    1 2 3 4 5 6 7 8
    X B2-S1 el.
    X B2-S2 el.
    X B2-S1 (delta-lambda shift)
    X B2-S2 (probe ageing)
    X B2-S1 (period)
    X EGR B1
    X EGR B2
    X B2-S1
    Measured value block 087:
    Ready and error bits
    1= not completed
    0= completed
    1 2 3 4 5 6 7 8
    X Heat.cat.
    X ACF system
    X SA system
    X Air conditioner
    X Lambda probes
    X EGR
    2)Error flags
    1= error
    0= no error
    1 2 3 4 5 6 7 8
    X Cat. bank 1
    X Cat. bank 2
    X LDP
    X TBV
    X Htg. B1-S1
    X Htg. B1-S2
    X Htg. B2-S1
    X Htg. B2-S2
    3)Error flags
    1= error
    0= no error
    1 2 3 4 5 6 7 8
    X B1-S1 el.
    X B1-S2 el.
    X B1-S1 (period)
    X SLS B1
    X SLS B2
    X B1-S1
    4)Error flags
    1= error
    0= no error
    1 2 3 4 5 6 7 8
    X B2-S1 el.
    X B2-S2 el.
    X B2-S1 (period)
    X EGR B1
    X EGR B2
    X B2-S1
    Measured value block 088:
    Cycle flags for other onboard diagnoses
    1)Cycle flags (completed cycles)
    1= not completed
    0= completed
    1 2 3 4 5 6 7 8
    X Exhaust camshaft bank 2
    X Exhaust camshaft bank 1
    X Inlet camshaft bank 2
    X Inlet camshaft bank 1
    X Knock sensor 4
    X Knock sensor 3
    X Knock sensor 2
    X Knock sensor 1
    1= not completed
    0= completed
    1 2 3 4 5 6 7 8
    X Clutch switch
    X Idling speed control
    X Road speed signal
    X Coolant temperature sensor
    X Throttle valve potentiometer
    X Air mass meter
    1= not completed
    0= completed
    1 2 3 4 5 6 7 8
    X Vacant
    X Vacant
    X Intake air
    X Thermostat (USA only)
    X Charge pressure control
    X CCS control lever
    X Lambda adaption B2
    X Lambda adaption B1
    Measured value block 089:
    OBD
    1))Kilometres driven with MIL [km] no readout for LEV
    2)Tank level [OK/Too low]
    3)
    4)
    Measured value block 090:
    Vacant
    Measured value block 091:
    Continuous inlet camshaft adjustment, bank 1
    2)Duty cycle [%]
    3)Adjustment specified [°CA] -14°CA...33°CA
    4)Adjustment actual [°CA] -14°CA...33°CA
    Measured value block 092:
    Vacant
    Measured value block 093: 2-bank systems
    Inlet camshaft adjustment values
    2) Load [%]
    3)Phase position bank 1 [°CA]
    4)Vacant
    The phase angle is the variation from the correct position (offset of Hall sender on shaft), 0 = position OK
    The phase angle is only displayed if the phase adaption was completed successfully.
    Measured value block 094: Basic setting
    Continuous camshaft adjustment, inlet
    - Press brake pedal and at same time press accelerator pedal down fully : Engine speed automatically adjusts to 2200 rpm -> "Test ON"
    - Wait for "Syst. OK" to appear in fields 3 and 4.
    2)Adjustment actual [°CA]
    3)Result bank 1 [Test on/ Test off/ Syst. OK/ Syst. n.OK]
    4)Result bank 2 [Test on/ Test off/ Syst. OK/ Syst. n.OK]
    Measured value block 095: Single-stage change-over
    Vacant
    Measured value block 096: Basic setting
    Vacant
    Measured value block 097:
    Vacant
    Measured value block 098
    Vacant
    Measured value block 099:
    Lambda control shut-off (via basic setting)
    (for sake of compatibility with old systems)
    3)Lambda controller [%]
    4) lambda control [off/on]
    Measured value block 100:
    Readiness code (for sake of compatibility with old systems)
    1= not completed
    0= completed
    1 2 3 4 5 6 7 8
    X Catalytic converters
    X Heat.cat.
    X ACF system
    X SA system
    X Air conditioner
    X Lambda probes
    X EGR
    3)Time since engine start [s]
    4)OBD status
    1 2 3 4 5 6 7 8
    X No warm-up cycle detected
    X Warm-up cycle detected
    X Vacant
    X Vacant
    X At least 1 fault detected
    X Trip complete
    X Driving cycle recognised
    X MIL on
    1: Description met
    0: Description not met
    Measured value block 101: Systems with air mass metering
    Injection
    2)Load [%]
    4)Air mass [g/s]
    Measured value block 102:
    Fuel injection
    4)Mean injection time [ms]
    Measured value block 103:
    Demand-regulated fuel pump
    1)Actual fuel pressure [mbar] 3000-7000
    2)I-controller fuel pressure [%/mbar]
    3)Elec.fuel pump adaption value [%/mbar]
    4)Fuel pump adaption [Test off/Adaption runs/Adaption OK/ERROR]
    Measured value block 104:
    Start adaption values
    1)Starting engine temperature [°C]
    2)Temperature adaption factor 1 [%]
    3)Temperature adaption factor 2 [%]
    4)Temperature adaption factor 3 [%]
    Measured value block 105:
    Vacant
    Measured value block 106:
    Fuel pressure
    1)Fuel rail pressure [bar]
    2)Electric fuel pump 1/2 [off / on or %PWM]
    3) Vacant
    4)Shut-off time [s]
    Measured value block 107: for 1-bank systems Basic setting
    Lambda control
    - Idle
    2)Lambda controller bank 1 (averaged value) [%]
    3) Vacant
    4)Result text [ Test ON / Test OFF / Syst. OK / Syst. n.OK ]
    Measured value block 108:
    Vacant
    Measured value block 109:
    Vacant
    Measured value block 110:
    Load/full throttle enrichment
    2) Coolant temperature [°C]
    4)Throttle valve angle (potentiometer) [%]
    Measured value block 111:
    1)Adaption value ISS engine speed range 1 [%]
    2)Adaption value ISS engine speed range 2 [%]
    3)Adaption value ISS engine speed range 3 [%]
    4)Adaption value ISS engine speed range 4 [%]
    Measured value block 112: 1-bank system
    Exhaust gas temperature
    1)Exhaust gas temperature bank 1 [°C]
    2)Enrichment factor sensor bank 1 [%]
    3)Precalculated exhaust gas temperature[°C]
    4)Modelled exhaust gas temperature[°C]
    Measured value block 113:
    1) Engine speed [rpm]
    2) Load [%]
    3)Throttle valve angle (potentiometer) [%]
    4)Ambient pressure [mbar]
    Measured value block 114:
    1)Specified load without correction [%]
    2)Specified load after correction [%]
    3) Actual load [%]
    4)Charge pressure valve duty cycle [%]
    Measured value block 115:
    2) Load [%]
    3) Specified charge pressure [mbar]
    4) Actual charge pressure [mbar]
    Measured value block 116:
    2) Correction factor, fuel [%]
    3)Correction factor, coolant temp. [%]
    4)Correction factor, intake air temp. [%]
    Measured value block 117:
    2) Accelerator pedal position [%]
    4) Specified charge pressure [mbar]
    Measured value block 118:
    2) Intake air temperature [°C]
    3)ISS valve duty cycle [%]
    4) Charge pressure before throttle valve [mbar]
    Measured value block 119:
    2)Current adaption value [%]
    Measured value block 120:
    TCS/FDR
    2)Specified torque TCS/FDR [Nm]
    3)Engine torque [Nm]
    4)Status [Text: TCS active/TCS n. active]
    Measured value block 121:
    Vacant
    Measured value block 122:
    Gearbox
    2)Specified torque Gearbox [Nm]
    4)Status [Text: Torque red/No red]
    Measured value block 123:
    Reserved for CAN bus messages
    Measured value block 124:
    Measured value block 125:
    CAN bus messages
    1)Gearbox [fitting info]
    - : No readout, if system not fitted, for
    all CAN bus messages
    Gear 0: No message yet received
    Gear 1: Message received
    2)ABS [fitting info]
    ABS. 0
    ABS. 1
    3)Combi [fitting info]
    Combi 0
    Combi 1
    4)AC [fitting info]
    AC 0
    AC 1
    Measured value block 126:
    CAN bus messages
    1)Distance [fitting info]
    Distance 0
    Distance 1
    2)Steering angle sender [fitting info]
    St.ang. 0
    St.ang. 1
    3)Airbag [fitting info]
    Airbag 0
    Airbag 1
    4)Elec. central electrics
    Elec. CE 0
    Elec. CE 1
    Measured value block 127:
    CAN bus messages
    1)Four-wheel drive [fitting info]
    4WD 0
    4WD 1
    2)Adaptive suspension [fitting info]
    Level 0
    Level 1
    3)Steering wheel [fitting info]
    Steering wheel 0
    Steering wheel 1
    4)Brake servo [fitting info]
    Brake servo 0
    Brake servo 1
    Measured value block 128:
    CAN bus messages
    1)Electric ignition lock [fitting info]
    El.ign. 0
    El.ign. 1
    2)NOx sensor 1 [fitting info]
    NOx sensor1 0
    NOx sensor1 1
    3)NOx sensor2 [fitting info]
    NOx sensor2 0
    NOx sensor2 1
    4) Engine CU/Slave CU
    Engine 0 / Slave_1 0
    Engine 1 / Slave_1 1
    Measured value block 129:
    CAN bus messages
    1)Battery / Energy manager [fitting info]
    E-Manag. 0
    E-Manag. 1
    2)Oil level sensor / ESI (TOG-Sensor) [fitting info]
    Oil level 0
    Oil level 1
    3)Gateway [fitting info]
    Gateway 0
    Gateway 1
    4) -
    Measured value block 130: Basic setting
    Map-controlled cooling
    - Idle
    1)Temperature engine outlet [°C]
    2)Temperature radiator outlet [°C] only A3
    3) Vacant
    4) Vacant
    Measured value block 131:
    2) Vacant
    3)Temperature radiator outlet [°C]
    4) Vacant
    Measured value block 132:
    Vacant
    Measured value block 133:
    Vacant
    Measured value block 134:
    Temperatures
    1) Oil temperature [°C]
    2)Ambient temperature [°C]
    3) Intake air temperature [°C]
    4) Engine outlet temperature [°C]
    Measured value block 135:
    Fan control
    1)Radiator outlet temperature [°C]
    2)Duty cycle fan actuator 1 [%]
    3)Duty cycle fan actuator 2 [%]
    4)Radiator fan drive circuit temperature [°C]
    Measured value block 136:
    Fan activation relays
    1)Vacant]
    2)Vacant
    3)Additional water pump [pump OFF/pump ON]
    4)Fan run-on [on/off]
    Measured value block 137:
    Air conditioner requests
    1)AC inlet [on/off]
    2)Compressor [on/off]
    3)High pressure switch / pressure from air conditioner [on/off / bar]
    4)Fan request from air conditioner [%]
    Measured value block 138:
    Thermostat diagnosis
    1)Engine start temperature [°C]
    2)Mean engine air mass [g/s]
    3)Mean vehicle speed [km/h]
    4)Result [Text: Test ON / Test OFF / Syst. OK / Syst. n.OK / Abort]
    Measured value block 139:
    1)Engine temperature in diagnosis [°C]
    2)Actual air mass integral [kg]
    3)Specified air mass integral [kg]
    Measured value block 140: Hitachi
    Fuel quantity control valve
    1) Fuel quantity control valve closing angle [°CA]
    2) Fuel quantity control valve opening angle [°CA]
    3)Rail pressure actual [bar]
    4)Status
    (Meaning of 8-digit number block)
    1 2 3 4 5 6 7 8
    X 1 = active / 0 = not active
    X Vacant
    X Vacant
    X Vacant
    X Vacant
    X Vacant
    X Vacant
    X Vacant
    Measured value block 141: Hitachi
    Fuel supply system
    1)High pressure system adaption [bar]
    2)Controller component [mm3]
    3)Total compression volume [mm3]
    4)Rail pressure (actual) [bar]
    Measured value block 142: Continuous adjustment Basic setting
    Charge motion flap for BDE
    - Idle
    1)Voltage upper limit [V]
    2)Voltage lower limit [V]
    3)Adaption status [n]
    4)Adaption status [ADP runs / ADP OK / ERROR]
    Measured value block 143: Continuous adjustment
    2) Load [%]
    3)Charge motion flap opening angle [%]
    4)BDE mode
    1 2 3 4 5 6 7 8
    X Homogeneous
    X Homogeneous lean
    X Homogeneous stratified dual injection
    X Stratified
    X Stratified cat heating dual injection
    X Vacant
    X Vacant
    X With bit 0 homogeneous knock protection
    Measured value block 144: Basic setting
    Vacant
    Measured value block 145: Basic setting
    Vacant
    Measured value block 146: Basic setting
    Vacant
    Measured value block 147: Basic setting
    Vacant
    Measured value block 148: Basic setting
    Desulphurisation NOx storage-type catalytic converter bank 1
    Vacant
    Measured value block 149: Basic setting
    Vacant
    Measured value block 150:
    Vacant
    Measured value block 151:
    Vacant
    Measured value block 152:
    Vacant
    Measured value block 153:
    Vacant
    Measured value block 154:
    Vacant
    Measured value block 155:
    Vacant
    Measured value block 156:
    Vacant
    Measured value block 157:
    Vacant
    Measured value block 158:
    Vacant
    Measured value block 159:
    Vacant
    Measured value block 160:
    Vacant
    Measured value block 161:
    Vacant
    Measured value block 162: Basic setting
    Vacant
    Measured value block 163: Basic setting
    Vacant
    Measured value block 164:
    Vacant
    Measured value block 165:
    Continuous control after main cat., bank 1
    Vacant
    Measured value block 166:
    Lambda probes plausibility, bank 1
    1)Lambda actual []
    2)Probe voltage after cat. [V]
    3)Integral air mass [g/s]
    4)Result [Test on/Test off/B1-S1 OK/B1-S1 n.OK]
    Measured value block 167: Basic setting
    Lambda probe overrun compensation
    - Idle
    1)Oxygen content [%]
    2)Diagnostic overrun counter []
    3)Steady lambda probe correction value characteristic [%]
    4))Result [Test ON / Test OFF /Activated/ADP runs/Syst. OK/Syst. n.OK]
    Measured value block 168: Basic setting
    Vacant
    Measured value block 169:
    Vacant
    Measured value block 170 -200:
    Vacant
  8. Re: G247 Fuel Pressure Sensor Help
    May 2007
    knee deep in clunge
    14 Post(s)
    mvbs 103 and 106 should help you
  9. Re: G247 Fuel Pressure Sensor Help
    131 Post(s)
    1974 Post(s)
    Quote Originally Posted by A4 Lad View Post
    Yes I have seen may FSI VAG cars play up due to lift pump failure and initially I was mistakenly changing pressure sensors but I soon learnt that the lift pump was most often the culprit IF there were no rich and lean (yes, both) lambda errors indicating that the main pressure pump was low in delivery and leaking fuel into the engine, hence rich and lean codes together which in normal circumstances doesn't add up.
    Oct 2010
    Here And There
    A8 matey, as always, thanks for the help. I have got lost in the mvb info but thanks for the help lol.
    Off the tools ? You wont like not getting your hands into it and you know it
    Crasher, thank you indeed. Im going for a drive tomorrow and will erase any faults and try flicking through the mvb that is mentioned. Ill check to see what sensor is in mine too and if I get a chance, pull out the lift pump and get a look
  1. help with fault code 16575 fuel pressure sensor
    By justin@justinwa in forum Golf MK5 - 2004 - 2009
    Last Post: 28-04-2012, 05:40 PM
  2. Exhaust pressure sensor
    By DMitch16 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-01-2012, 10:30 PM
  3. fault code 1121 fuel pressure sensor
    By IRISH QUATTRO in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-01-2011, 07:43 AM
  4. oil pressure sensor
    By mand in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-12-2009, 08:36 PM
  5. fuel pressure sensor
    By adamk in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-06-2009, 08:47 PM
