Thread: Audi A3 07 - No Engine Mgmt Light but error code P0171
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Audi A3 07 - No Engine Mgmt Light but error code P0171
    May 2013
    London
    I've got the car mentioned in the thread title. I ran the VCDS through and got the log as below. There is no Engine Management light on; car runs absolutely fine and I've managed about 225miles from half a tank (I am thinking it's good - but i'm sure it could be better)
    Could someone help me in understanding the following log? i.e. what parts will I need to change etc? I've read on Ross-tech's website and it seems the MAF filter but if someone can confirm it for sure before I go ahead with the change, I would really appreciate it.
    Cheers.
    Control Module Part Number: 06A 906 033 EH
    3 Faults Found:
    16555 - Fuel Trim; Bank 1
    P0171 - 006 - System Too Lean - Intermittent
    Freeze Frame:
    Lambda: 25.0 %
    Lambda Factor: 1.008
    Voltage: 0.440 V
    Speed: 0.0 km/h
    Lambda: 25.0 %
    Lambda Factor: 1.000
    Voltage: 0.440 V
    Speed: 0.0 km/h
    17511 - Oxygen (Lambda) Sensor Heating; B1 S1
    P1103 - 006 - Performance too Low - Intermittent
    Freeze Frame:
    RPM: 608 /min
    Mass Air / Rev.: 92.7 mg/str
    Resistance: 0.00 kOhm
    Hex Value: 0x0001
    17658 - Fuel Level too Low
    P1250 - 000 -
    Freeze Frame:
    Readiness: 0000 0000
  2. Re: Audi A3 07 - No Engine Mgmt Light but error code P0171
    46 Post(s)
    Can you post the full log?
    Did you see a time and date - if its old, it may have been fixed and not deleted from the cars memory.
    Press Applications in VCDS' main menu, then Erase All DTCs, do a few ignition cycles and rescan.
  3. Re: Audi A3 07 - No Engine Mgmt Light but error code P0171
    May 2013
    London
    Thanks for the reply Chris. Only thing missing from the log is:
    Component and/or Version: SIMOS71 1.6l 2V 9429
    Software Coding: 0000071
    Work Shop Code: WSC 06314 000 00000
    VCID: 69DDC2F0407D1250962
    Unfortunately it was someone else's VCDS and I can't do a re-scan etc :/
    Is it worth getting the cheap ones being sold on eBay?
  4. Re: Audi A3 07 - No Engine Mgmt Light but error code P0171
    Aug 2011
    Meath
    NOPE
    Is it worth getting the cheap ones being sold on eBay?[/QUOTE]
  5. Re: Audi A3 07 - No Engine Mgmt Light but error code P0171
    Pembrokeshire
    22 Post(s)
    never start fixing stuff by going on codes where the fault may have already been fixed years ago and the code not deleted, as chris rightly points out.
    scan again, clear the codes, drive, re scan, fix current faults. anything else is just bonkers unless you need to get rid of some money.
    1 1 0
  6. Re: Audi A3 07 - No Engine Mgmt Light but error code P0171
    May 2013
    London
    Cheers for your input chaps. I honestly don't want to throw money but because there is an error I would like to know the cause of it since it drives me nuts that there is something wrong with what I've got
    Something major that I have missed out is that it's a 1.6 Petrol which doesn't have an MAF - unless I'm talking rubbish...
  7. Re: Audi A3 07 - No Engine Mgmt Light but error code P0171
    May 2013
    London
    Got vehicle scanned again, 3 times, and no errors were found. Scanned while it was switched off; scanned after starting it; scanned while it was on. Nothin in all 3 instances :/
    Utter non-sense!!!
  8. Re: Audi A3 07 - No Engine Mgmt Light but error code P0171
    Feb 2011
    Whats performance and fuel consumption like?
    I ask because I used to have a Golf 1.6 FSI and I had nothing but problems with it because of the exhaust/fuel/emissions system
    Ended up changing NOX sensor, cat... on and on it went until I threw it out
  9. Re: Audi A3 07 - No Engine Mgmt Light but error code P0171
    1836 Post(s)
    Should have fixed it properly then, not just amateurishly throwing random parts at it...
    0 1 1
  10. Re: Audi A3 07 - No Engine Mgmt Light but error code P0171
    Feb 2011
    This "amateur" nature was VW not myself. I dont know the last time you went into a dealership but thats all they ever do these days. Never said I was a professional but thanks for your excellent input. Clearly contributes a lot to the ops thread.
    0 0 1
  1. P0171 code - Looking for leaks help :) Engine Pics
    By sergioiacobucci in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-06-2015, 01:37 PM
  2. Replies: 0
    Last Post: 09-07-2009, 03:03 PM
  3. Please Help Engine mgmt light on A3 2.0 Tdi on an 05plate
    By tampingtastic in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-06-2009, 10:58 PM
  4. audi a4, code p0171
    By muffin in forum Audi A4 - Archive Topics
    Last Post: 11-11-2006, 11:01 PM
  5. audi a4, code p0171
    By muffin in forum Archive posts
    Last Post: 11-10-2006, 08:38 PM
