Thread: Audi/VW engines with DPF
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Audi/VW engines with DPF
    Aug 2011
    Slough, England
    Could anyone please help me. I am thinking of buying either an Audi A3 or Seat Leon diesel 2005 onwards, does anyone know if these diesel engines have a DPF as I would be driving mainly locally in town to commute to and from work. I have been told that diesels with DPF cause alot of problems especially when driven mainly locally and are very expensive to repair.
    Any advice or help will be much appreciated escpecially if anyone can tell me which diesel engines have a DPF fitted and from what year onwards.
    Thanx
  2. Re: Audi/VW engines with DPF
    Aug 2011
    Aldershot
    6 Post(s)
    I think the answer is as follows:
    The 170 BHP has a DPF filter, the 140 did not, however it has a major issue with the chain driven oil pump on the earlier models (around 2004 - 2006)
    The 1.9tdi engine is the most reliable and economical of the bunch, but lacks power without a remap.
    The 3.0tdi on the early versions I don't think had a DPF, but when they upped the BHP from 201 to 233, they added a DPF filter.
    I have no idea on the 2.7tdi.
    Paul
  3. Re: Audi/VW engines with DPF
    Nov 2009
    46 Post(s)
    If you can check the option codes on the data sticker in the spare wheel well - if you see 7GN anywhere the car does not have a DPF.
  4. Re: Audi/VW engines with DPF
    1837 Post(s)
    I think 2008 onwards they all have a DPF and some earlier ones too.
  5. Re: Audi/VW engines with DPF
    Aug 2011
    Slough, England
    Thanx alot Paul for the advice, I guess that means I should be lookin for 1.9 Tdi then as I dont want to be paying for any expensive repair bills. Thnx again.
  6. Audi/VW engines with DPF
    Mar 2009
    Essex
    Just for info my 2007 2.0 tdi 140 DOES have a DPF fitted. Until they became standard on all it was an option - that my lease company decided to take up in its wisdom.
  7. Re: Audi/VW engines with DPF
    Aug 2011
    Slough, England
    Are all the 1.9 Tdi engines without the DPF cuz i have seen a Seat Leon 1.9Tdi 2007 and an Audi A3 1.9Tdi also 2007, they share the same parts with Audi/ VW but I dont know if they also hav a DPF or not.
  8. Re: Audi/VW engines with DPF
    Mar 2009
    Essex
    Yes
  9. Re: Audi/VW engines with DPF
    Nov 2009
    46 Post(s)
    Quote Originally Posted by EssexGonzo View Post
    Yes
    not true - my 2009 1.9 has a dpf
    only way to tell is look at the option code i stated in my previous post.
    i think dpf only became mandatory in 08/58 plate cars
  10. Re: Audi/VW engines with DPF
    1837 Post(s)
    It is impossible to avoid a DPF on a derv car after 2008 ish, get used to it and NO DPF delete is not the Valhalla people think, currently I am trying to sort out two A3's with DPF delete that are running like ****!
  1. Question CR Engines, Do they all have DPF?
    By philipharmes in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-01-2012, 06:12 PM
  2. Audi TDI 140 engines
    By bakili in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-11-2010, 09:14 AM
  3. Can anyone list the pre DPF engines?
    By skodaescapee in forum Jetta MK3 - 2005 - 2013
    Last Post: 07-08-2010, 06:03 PM
  4. New Audi A4 engines???
    By skymaster in forum Chat - Anything with wheels
    Last Post: 27-12-2007, 04:22 PM
  5. The Audi Diesel Engines - Pure Power
    Last Post: 10-01-2007, 09:34 PM
