Thread: New bush or the entire arm?
  1. New bush or the entire arm?
    Mar 2013
    Reading
    31 Post(s)
    So, last year during the inspection and MOT, I was told that my front lower radius arm to chassis bush started to split (have a nice Audi cam with the evidence).
    Should I go the route of powerflex (£52 per bush only for the purple stuff) or get the new Arm altogether (Lemforder/Metzger are on the £91 mark)?
    I'd rather do the right thing as on both cases it is the arm out job...
    Sent from my mobile...
  2. Re: New bush or the entire arm?
    1840 Post(s)
  3. Re: New bush or the entire arm?
    Mar 2013
    Reading
    31 Post(s)
    Thanks Crasher. That's exactly what I was looking at (my reference to the "purple stuff"). So you recon no point to replace the whole arms? How robust are the ball joints (as they might be ok now but give ghost just a bit later)?
  4. Re: New bush or the entire arm?
    1840 Post(s)
    So far they appear to be reliable but in about 50% of cases we fit a new Febi arm AND the Powerflex bush when asked to. If you buy them from that link it makes the other half of C&R's left lip just show approval...
  5. Re: New bush or the entire arm?
    Mar 2013
    Reading
    31 Post(s)
    And is it worth looking at the black series or not?
  6. Re: New bush or the entire arm?
    1840 Post(s)
    We only use them in places that take an extreme battering, the classic example is the PQ35/46 platform rear lower spring plate inner bush. This is much smaller then VAG should really have made it and takes an extremely heavy load in all directions so Powerflex only do it in black hard poly, I think you could find you need to all of them if you did one area in very hard material.
    1 2 0
  7. Re: New bush or the entire arm?
    Mar 2013
    Reading
    31 Post(s)
    You Sir are a true gem on this forum!
  8. Re: New bush or the entire arm?
    Mar 2013
    Reading
    31 Post(s)
    Finally got some time to sort things out... Order placed today!
  1. Help with replacement headlight lens or entire unit
    By AMA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-09-2013, 04:53 PM
  2. New Key/Refitting entire lock system
    By hairyape1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-04-2012, 09:28 PM
  3. Pads not covering entire disc surface
    By allymac in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-05-2011, 05:58 PM
  4. Question 53 1.2 Polo - I don't have to remove the entire front to adjust the headlight do I? Do I?!
    By scottpa100 in forum Polo - Derby - Lupo - Fox
    Last Post: 18-09-2010, 08:45 AM
  5. Replace an entire door
    By Sprech in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-05-2010, 01:49 PM
