Thread: Stop!!! Low Oil Pressure!!!!!
Results 1 to 10 of 20
  1. Stop!!! Low Oil Pressure!!!!!
    Aug 2007
    hi all
    i'm starting to panic
    as of late i have been driving from southampton to northampton.
    after 90 odd miles of 90 mile/hr driving, when i slow down at a few roundabouts, i get a low oil pressure warning, panic and pull over.
    if it takes a little while to pull over, usually the warning will disappear before i have a chance to stop
    the warning only comes on once and then disappears, its not continuously on.
    then everythings fine for a few miles maybe and it will happen again.
    most days it wont happen at all
    i have a 1.8t sport estate, W/2000 engine is an APU, mileage is 138,000
    it is actually due a service now. oil is mobil 1 0W/40. oil level is perfect although i do have a "large" oil leak according to main dealer when i had cambelt and tensioners replaced 5000 miles ago. (in 5000 miles since oil change, level of oil has hardly changed, so much for "large" oil leak. they wanted £270 to fix it)
    hopefully thats enough background
    what should be my first port of call
    thanks in advance
    BUB
  2. Re: Stop!!! Low Oil Pressure!!!!!
    135 Post(s)
    2026 Post(s)
    The sump needs to come off so the oil pump pick up pipe can be cleaned out and the inside of the engine scrubbed clean. If you continue to drive it you will destroy the engine and turbo, this is an extremely common problem on the 1.8T engine, especially when used in the Passat, A4 and A6.
  3. Re: Stop!!! Low Oil Pressure!!!!!
    Aug 2007
    hi crasher
    is this a job i can do without a ramp or more of a specialist type job?
    also, will using 0W/40 be any part of the problem?
  4. Re: Stop!!! Low Oil Pressure!!!!!
    Aug 2007
    ok, i've just booked it in at an independant for tomorrow.
    i mentioned the sludging problem to him and asked for a price for that job, (sump off) and was advised that the first thing they would do is a diagnostic (£35) then go from there.
    he said it might be a faulty pressure switch
  5. Re: Stop!!! Low Oil Pressure!!!!!
    135 Post(s)
    2026 Post(s)
    The subframe has to be dropped down which is quite involved.
    The oil you are using is perfect for the job, it’s just that these engines are prone to sludge formation.
    It will not be the switch the way it is playing up, it is telling the truth.
  6. Re: Stop!!! Low Oil Pressure!!!!!
    Aug 2007
    crasher, thanks mate, one question
    is it worth trying an engine flush first, then rinsing out with some cheap oil, and then re-filling with the good stuff
    if so, can you recommend a flush product for the job
    thanks again
    BUB
  7. Re: Stop!!! Low Oil Pressure!!!!!
    135 Post(s)
    2026 Post(s)
    No, it must be cleaned out manually, the pickup pipe is blocked with sludge. I flush after I have put it back together and I use Comma flushing oil or similar.
  8. Re: Stop!!! Low Oil Pressure!!!!!
    Aug 2007
    after extensive diagnostics, road test etc, they are very confident the oil pump is goosed. (£370 fitted)
    it is being fitted tomorrow
    how does that sound?
  9. Re: Stop!!! Low Oil Pressure!!!!!
    135 Post(s)
    2026 Post(s)
    Fitting a new oil pump is not a bad idea whilst you are in there but it won’t be the problem, it will be a blocked pump intake screen. A genuine oil pump is nearly £180 and a pattern one about half that. On top of that there is the at least four hours it takes to drop the subframe, change the pump, clean out the sump and rebuild then have the front wheel alignment checked if they did not use subframe locking pins and even if they do, realignment is sometimes necessary anyway. So four hours at £50 per plus pump is about £380 and on top of that there is oil and filter plus bolts, so a bit cheap to be honest.
  10. Re: Stop!!! Low Oil Pressure!!!!!
    Aug 2007
    sorry crasher, thats probably plus VAT.
    i will ask if they have used a vw genuine part
    thanks again
  1. Please Help STOP: Oil pressure
    By blackpassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2009, 08:53 PM
  2. STOP! engine oil pressure warning
    By del_boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-11-2008, 03:19 PM
  3. Engine Oil Pressure Warning (STOP) - please help
    By Nedx in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-10-2008, 10:41 PM
  4. STOP ! Low Oil Pressure Warning
    By Tnarg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-01-2008, 11:33 AM
  5. STOP on display??????
    By Big G in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2007, 12:09 PM
