Thread: Loose Door Handle
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
  1. Re: Loose Door Handle
    Mar 2007
    Does anyone know how the steel clip is fitted to the back of the handle .
    ie does the clip slide down from above , or from front to back , or back towards the front ? I think that you can push a credit card between the door and the open handle and push the clip back into place , maybe , if i could find out which way ...
  2. Re: Loose Door Handle
    the proper way to fix it is to slide the metal clip behind the handle towards the rear of the car. i'll try and explain...
    1.lock the car
    2. lift the 'loose' handle
    3.using a flat blade long screwdriver look for a metal tab roughly in the middle of the handle near the top(you need to press your face against the door and look towards the rear of the car to see it)
    4. basically that needs tapping back abit
    not the best explanation but hey i tried
    2 0 0
  3. Re: Loose Door Handle
    Aug 2007
    Weybridge
    Have a guess what I'll be upto this weekend!
    This has been bugging me for weeks.
    Cheers guys
  4. Re: Loose Door Handle
    Lancashire
    Quote Originally Posted by MATT2OOSX View Post
    1.lock the car
    Nice one I'll give that a bash this weekend
    54 Audi A4 Avant 1.9TDi 130 SE 6-speed, RNS-E, rear parking sensors, bluetooth
  5. Re: Loose Door Handle
    Edinburgh
    I've been experiencing the exact same problem with my drivers door handle. I listed it on here some time ago, but no fixes were suggested. Happy to see a few fixes now listed, will hopefully get the time to try one soon.
    Has anyone had a problem with actual door dropping?? just very slightly?? Every now and again, if I don't close the door with enough force the door doesn't close properly. It's nothing major but it's the only thing that annoys me about my car.
    I've heard of grabbing the bottom of the door and yanking it upwards with some vigour, anyone had any success with this method.? More to the point has anyone done anything adverse using this method..? Comments appreciated.
    the dude abides..........
  6. Thumbs up Re: Loose Door Handle
    Mar 2007
    FIXED IT !!!!!!!!!!
    Thanks to MATT200SX on his Post .
    I locked the door , looked down onto the top of the handle and could see the stainless clip just forward of the centre , i tried to get a small screwdriver between the door and the lifted handle but was afraid of marking the paintwork on the door . So i got an old "Nectar" card , slid it between the door and the handle at the front end , then slid it towards the back of the handle until i felt it had hit the clip , i then tapped the "Nectar" card towards the back , the card moved about 3mm and the job was a done . No More Rattles !!!!!
    2 0 0
  7. Re: Loose Door Handle
    #17
    Aug 2007
    Weybridge
    Quote Originally Posted by Dillon's A4 View Post
    FIXED IT !!!!!!!!!!
    Yeah Cheers Matt200sx, problem solved
    Took some pic's as I did it as the handle cover fell off in the process
    Pic 1 is with no cover and shows the clip at the top of the handle which needs to be pushed towards the back of the car.
    The others show me doing this with a card - with and without handle cover (like you Dillion A4 didn't what to scratch paint with screwdriver)
    11 0 0
  8. Thumbs up Re: Loose Door Handle
    #18
    Edinburgh
    Finally got a chance to try this and it worked..!! Very pleased indeed.
    Thanks for the tips.. appreciated.
  9. Re: Loose Door Handle
    #19
    Northern Ireland (Antrim)
    Removed Silicon & did the credit card fix. Worked great!!! Thanks for tip guys!!!
  10. Re: Loose Door Handle
    #20
    Dec 2007
    get anew clip from *******s remove door panel fit remove old clip refit new clip done easy
  1. Inside door grab handle
    By redadair in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-02-2008, 08:43 PM
  2. golf mk4 door handle
    By valley rower in forum Golf MK4 - 1999 - 2004
    Last Post: 03-06-2007, 12:40 PM
  3. Drivers exterior door handle problem
    By Niall76 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-04-2007, 09:24 AM
  4. Passenger Door Handle
    By neilc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-04-2007, 10:07 PM
  5. A4 avant 2.5 tdi quatro steering, air con, door handle
    By tkboy in forum Chat - Completely Off Topic
    Last Post: 20-11-2006, 03:05 PM
